Number of specific piece of polar array as expression
I'm trying to model a cycloidal gear reducer, and I need to be able to model a cycloidal disk.
https://en.wikipedia.org/wiki/Cycloidal_drive
The edge of cycloidal disk can be generated by rolling a secondary circle around a primary circle, and tracking an edge point of the secondary circle as it rolls. This should be doable with a sketch using expressions. I can generate multiple instances of the sketch with a polar array, but each piece in a polar array should calculate a point with an expression, based on which piece of polar array it is.
https://imgur.com/a/xPfxeGB
Can I use the number of specific polar array as an expression? If I have a Number P = 63, then each piece of this array would have a specific value from 1 to 63, and I could use a variable e.g. numberOfCurrentPolarArray to calculate parts of the sketch.. Is this possible?
A workaround would be to know the current angle from X/Y/Z axis.
Re: Number of specific piece of polar array as expression
Using Array.NumberPolar gives me the amount of polar arrays. I'd need a specific number of individual polar array. Lets say I have NumberPolar = 3 and I have a length constraint based on "f = currentpolar * 3mm". want the following results per piece of array:
Results should be:
Array piece 1, constraint (length): 3mm
Array piece 2, constraint (length): 6mm
Array piece 3, constraint (length): 9mm
Using f = Array.NumberPolar * 3mm would result in 9mm for each, which is not desired for this application.
Results should be:
Here is a sample image of something I'd like to achieve...
https://imgur.com/a/z625MoF
It's made of 45 sketches, each has an angle value, and the other values are calculated based on this.
Trying to achieve something like this...
https://www.tec-science.com/mechanical- ... idal-disc/
and this...
https://www.youtube.com/watch?v=guvatctnjww
and this...
Firstly if the following macro is of use then no credit should come in my direction as the base script came from this topic https://forum.freecadweb.org/viewtopic.php?t=33239unelsson wrote: ↑Sun Sep 22, 2019 10:07 pm Trying to achieve something like this...
1) Copy the script below and save as a FCMacro file in your macro folder
2) In an existing file or new file change to the Sketcher Wb and create a new sketch in XY plane
3) Execute the new macro file
If it produces something like what you require then obviously you will need to adjust the parameters at the top of the file to suit your requirements.
LargeRadius = 180.0
SmallRadius = 20.0
nbPas = 120
excentrique = 6.0
EpiCycloidAngle = 9.5
# Large line length= sum of the radiuses
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10,23,0),App.Vector(27.354679,55.016010,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident',0,1,-1,1))
c=ActiveSketch.addConstraint(Sketcher.Constraint('Distance',0,LargeRadius+SmallRadius))
ActiveSketch.setVirtualSpace(c, True)
La=ActiveSketch.addConstraint(Sketcher.Constraint('Angle',-1,1,0,1,2*3.141592653589793*EpiCycloidAngle/360.0))
ActiveSketch.setVirtualSpace(La, True)
#ActiveSketch.setDatum(La,App.Units.Quantity('0.000000 deg'))
# arc de cercle small radius
ActiveSketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(25,31,0),App.Vector(0,0,1),12),-2,0.4),False)
c=ActiveSketch.addConstraint(Sketcher.Constraint('PointOnObject',1,1,0)) # start of the Arc on the large line
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident',1,3,0,2)) #center at end of the large line
c=ActiveSketch.addConstraint(Sketcher.Constraint('Radius',1,SmallRadius))
# Small line
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(26,35,0),App.Vector(34,38,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident',0,2,2,1)) #start at the end of the large line
c=ActiveSketch.addConstraint(Sketcher.Constraint('Distance',2,excentrique))
c=App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('PointOnObject',1,2,2))
Sa=ActiveSketch.addConstraint(Sketcher.Constraint('Angle',0,2,2,1,0)) #creer contrainte a 0 (radian))
ActiveSketch.setVirtualSpace(Sa, True) # make the angle constraint invisible to improve drawing understanding
n=0
Sv= ActiveSketch.Geometry[2].EndPoint
Lad = (360.000000/nbPas)
Sad = Lad * (LargeRadius/SmallRadius)
if True:
while n < nbPas :
n += 1
App.ActiveDocument.Sketch.setDatum(La,App.Units.Quantity(str(Lad*n+EpiCycloidAngle) + ' deg'))
App.ActiveDocument.Sketch.setDatum(Sa,App.Units.Quantity(str(Sad*n) + ' deg'))
Ev= App.ActiveDocument.Sketch.Geometry[2].EndPoint
App.ActiveDocument.Sketch.addGeometry(Part.LineSegment(Sv,Ev),False)
Sv=Ev
#clean up of the geometries used to buid the epicycloid
App.ActiveDocument.Sketch.delGeometry(2)
App.ActiveDocument.Sketch.delGeometry(1)
App.ActiveDocument.Sketch.delGeometry(0)
Wow! Thanks. It's a good start.
Currently failing with an error (on Manjaro Linux):
ViewProviderSketch::setEdit: visibility automation failed with an error:
File "<string>", line 2, in <module>
<class 'TypeError'>: 'module' object is not callable
Works fine using 0.19pre Appimage if that's any use:
OS: Linux Mint 19.1 (X-Cinnamon/cinnamon)
Version: 0.19.18260 (Git) AppImage
Hash: dbf0644b60c35273525985fa13859ad39b0c10df
Python version: 3.7.3
Qt version: 5.12.1
Qt version: 5.12.1
In 0.18.3 Appimage it also does seem to work. Something strange with my build probably. Thanks a lot!
- DeepSOIC
Clean build may help.
If it doesn't. Can you check if there is TempoVis.py file in <wherever_freecad_builds_into>/Mod/Show? If there are both TempoVis.py and mTempoVis.py, delete the one without the m prefix, and test. In theory, the presense of (old) TempoVis.py shouldn't cause trouble, but maybe it does.
- DeepSOIC
It is NOT doable within FreeCAD. But it is doable in Lattice2, using a tool named "ParaSeries", that can use one sketch and compute the results by varying a constraint for example.unelsson wrote: ↑Sat Sep 21, 2019 10:40 pmThe edge of cycloidal disk can be generated by rolling a secondary circle around a primary circle, and tracking an edge point of the secondary circle as it rolls. This should be doable with a sketch using expressions. I can generate multiple instances of the sketch with a polar array, but each piece in a polar array should calculate a point with an expression, based on which piece of polar array it is.
This tutorial should help you get familiar with ParaSeries: https://github.com/DeepSOIC/Lattice2/wi ... t-Tutorial
The problem solved by the tutorial is quite different to yours, but I hope you can extrapolate.
Also, it may be more easy to use clever geometric construction to make an approximation of the shape with a few segments of a circle. Like I did to make a tractrix shape in sketcher very very long ago: https://forum.freecadweb.org/viewtopic.php?t=7822
