Toggle Clasp For Necklace Project
Attached is my project (Capture.PNG) and an example of a toggle clasp (toggle clasp.PNG) for a necklace. I want to attach a toggle clasp in the way shown to the top of my project so that the whole is perpendicular to the front face of the project. It does not need to be exactly as shown in the image, whatever the best/easiest method for something like this will do. The purpose is to put a chain through the whole and essentially have a necklace. I'm looking for any videos that would assist me or any help would be appreciated.
I am also searching for a website to get my design manufactured(metal) from. Any recommendations for the best or cheapest methods of getting this done?
Thanks
Thanks
- toggle clasp.PNG (85.73 KiB) Viewed 1783 times
- Capture.PNG (12.91 KiB) Viewed 1783 times
Re: Toggle Clasp For Necklace Project
Hello d_oshea,
for the next time, please read this thread carefully before opening a new thread: https://forum.freecadweb.org/viewtopic. ... g for help
Especially these information is missing:
Regards
Max
Because you haven't provided your FreeCAD file, I've designed a new kind of neglace I'm not sure which side you're refering to as "top". Does my result look like what you're trying to do? Another way could be to create a second body, model the toogle clasp as you like (based on my first solution) and fuse both bodies together (the neglace part and the toogle clasp). My first solution is a little dirty, because I've just placed the toogle clasp inside the neglace part. Please let me know if you would like to get an example of the second solution too.4. Please provide your FreeCAD version info
6. Add your FreeCAD file and/or screen captures
What kind of material do you have in mind? You could use a CNC-mill or a coping saw and create the neglace and the toogle clasp seperately and weld solder them together. Or you could use a supplier like https://www.shapeways.com/ Shapeways or https://www.3dhubs.com/ 3D Hubs to get it printed in one piece (in metal or plastic). 3D Hubs offers CNC Machining too.
Regards
Max
- 2019-10-06_ToggleClaspForNecklaceProject_1.FCStd
- (26.32 KiB) Downloaded 51 times
Regards / Viele Grüße
Max
Max
- pl7i92LCNC
for manufacture if thickness is lower then 3mm it is lasercut
above you may need the watercat guys to manufacture
depending on where you are you will get it nearby
I've to correct myself (kind of). Depending on how you're modelling your toogle clasp, you won't need a second body. Especially if you're designing it to be manufactured in a single piece. I guess I was too tired last night
This is how I would do it if I would be aiming for a 3D print for example.
Of course lasercut is another option! Since you're talking about a neglace, I guess your part is not going to be very big or thick...?pl7i92LCNC wrote: ↑Sun Oct 06, 2019 7:51 am for manufacture if thickness is lower then 3mm it is lasercut
Hope this helps!
Max
- 2019-10-06_ToggleClaspForNecklaceProject_3.FCStd
- (29.36 KiB) Downloaded 49 times
Max
Max
- pl7i92LCNC
neglace and Hanging are usaly soldert together then it is painted or cromed
Apologies, I should have read the guidelines more clearly.
Thanks for your help, the second design is exactly what I was looking for. I was planning on getting cut all as one piece. The diameter will be 2/2.5mm so it will need to be laser-cut.
I've also attached the file I'll be working on.
Thanks
Thanks
- DAVID normal.FCStd
- (87.59 KiB) Downloaded 45 times
Hi,pl7i92LCNC wrote: ↑Sun Oct 06, 2019 5:43 pm neglace and Hanging are usaly soldert together then it is painted or cromed
Thanks
I'm glad that I was able to help you! What I don't get is how you're planning to let it cut in one piece if you're designing it with the toogle clasp.
Max
Max
I'm not sure I follow, do mean because the toggle clasp is 90 degrees to the rest of the project? Does it need to be facing the other way for it to cut in one piece?
Imagine you've a 3 mm thick sheet of metal and a saw. Everything you're able to cut out of it without turning it around can be cut out of it with a laser. That's why everything has to be of the same height and holes / cut outs are only possible from "top" to "bottom".
Max
Max
