Importing or opening xlsx file results in blank spreadsheet
Venefyxatu
Postby Venefyxatu » Thu Sep 26, 2019 9:01 pm
As the title says.
I've tried a few combinations:
  • Opening an Excel-generated xlsx file results in a spreadsheet with the correct name, but no content
  • Opening a LibreOffice-generated xlsx file results in a spreadsheet with the correct name, but no content
  • Importing an Excel-generated xlsx file results in a spreadsheet called Spreadsheet with some garbage characters
  • Importing a LibreOffice-generated xlsx file results in a spreadsheet called Spreadsheet with no content
By way of experiment, I installed the latest FreeCAD on a Windows 10 virtual machine, but everything I did there (File -> New, File -> Open) resulted in the window going completely black. I guess it's not happy about running under VirtualBox :-)
I've attached basic_specs.xlsx (LibreOffice-generated) and basic_specs_excel.xlsx (Excel-generated) in case anyone wants to experiment.
My search also led me to https://www.freecadweb.org/tracker/view.php?id=2737 , but that issue was closed as fixed sometime in 2016.
I've also encountered a forum thread somewhere advising someone to get rid of system.cfg and user.cfg, so I did that as well without noticeable results.
There are no non-unicode characters in any of the paths involved (/home/erik and /home/erik/Downloads).
Linux FreeCAD information:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
Where do I go from here? File a bug report? Is there something else I can try? Something I can do to help figure out what the problem is? My first guess would be I'm missing a library somewhere, but I have no idea which one.
basic_specs.xlsx
(4.65 KiB) Downloaded 75 times
(9.4 KiB) Downloaded 75 times
Re: Importing or opening xlsx file results in blank spreadsheet
Postby chrisb » Thu Sep 26, 2019 11:29 pm
Import of xlsx files is not expected to work Documentation says that only CSV files can be imported: https://www.freecadweb.org/wiki/Spreads ... _exporting
kisolre
Postby kisolre » Fri Sep 27, 2019 7:48 am
Actully... second paragraph :-)
Postby chrisb » Fri Sep 27, 2019 7:52 am
Ooooops :oops: :oops: Thanks for the clarification.
Roy_043
Postby Roy_043 » Fri Sep 27, 2019 8:35 am
There is an error in the Report view:
File "C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet\importXLSX.py", line 480, in insert
handleWorkSheet(myDom, theSheet, stringList)
File "C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet\importXLSX.py", line 329, in handleWorkSheet
handleCells(row.getElementsByTagName("c"), actSheet, strList)
File "C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet\importXLSX.py", line 374, in handleCells
actCellSheet.set(ref, (sList[int(theValue)]).encode('utf8'))
<class 'TypeError'>: set() argument 2 must be str, not bytes
So this is definitely a bug.
Syres
Postby Syres » Fri Sep 27, 2019 9:19 am
Having done a few tests with some Excel files of my own, it would appear src\Mod\Spreadsheet\importXLSX.py needs some (more) love but this bug can be fixed by changing at line 57:
import zipfile
import xml.dom.minidom
import FreeCAD as App
try: import FreeCADGui
to
import zipfile
import sys
and at line 374 from:
          if cellType == 's':
def handleWorkBook(theBook, sheetDict, Doc):
to
          if cellType == 's':
            if sys.version_info.major >= 3:
                actCellSheet.set(ref, (sList[int(theValue)]))
            else:
I'll submit a PR for this to be ready for 0.18.4.
papyblaise
Postby papyblaise » Fri Sep 27, 2019 9:45 am
Hello
I open your file whith OpenOfice
I open a spreadsheet in Fc
Copy / Past , that all
import xls.PNG (27.67 KiB) Viewed 377 times
Venefyxatu
Postby Venefyxatu » Fri Sep 27, 2019 10:54 am
Wow, you people are fast :shock:
Syres: your patch works for me, thanks!
papyblaise: that's indeed what I've been doing as a workaround, although as soon as you start using formulas it shows its limitations, as only the values are copied. Still, good enough when getting started :-)
Syres
Postby Syres » Fri Sep 27, 2019 12:09 pm
PR Submitted https://github.com/FreeCAD/FreeCAD/pull/2558 and requested backport to 0.18
papyblaise
Postby papyblaise » Fri Sep 27, 2019 1:05 pm
So it's your spreadsheet that should be put in the right format, tell him to display the formulas and you will import the formulas and not the result
import et formules.PNG (26.27 KiB) Viewed 344 times
