signal emit when closing a sketch
ebrahim raeyat
Postby ebrahim raeyat » Fri Sep 27, 2019 3:30 am
First excuse me for posting sketch related subject in this forum, because i didn't find related subject for SKETCH.
I have an axis that their lines is very close to each other, like below:
i decide to draw them with sketch to allowing the user to move them in a desired place. then i want to know the signal that emit when a sketch is closed to move text label in appropriate place in circles.
Re: signal emit when closing a sketch
Postby chrisb » Fri Sep 27, 2019 4:46 am
Moved to Help forum. That's where Sketcher issues are discussed.
If I understand you right the issue is to keep the text centered inside of the circles right? Are your Sketches created from PartDesign workbench (i.e. inside of a PartDesign body) or from Sketcher (outside of PartDesign body)?
Postby chrisb » Fri Sep 27, 2019 5:33 am
Here is my PartDesign proposal:
- Create a sketch with only the degrees of freedom left, the user is allowed to move
- Create a ShapeString
- Move the ShapeString into the body
- Create a DatumPoint in the middle of the circle
- Attach theShapeString to the DatumPoint
- Change the AttachmentOffset of the ShapeString so that it is centered in the circle.
Now the ShapeString follows changes made in Sketcher. If AutoUpdate is unchecked, the Update will happen as soon as Sketcher is closed.
movingShapeString.FCStd
(7.56 KiB) Downloaded 1 time
ebrahim raeyat
Postby ebrahim raeyat » Fri Sep 27, 2019 1:11 pm
I use sketcher, here is my scripts:
import Sketcher
import FreeCAD
import FreeCADGui as Gui
import Part
import Draft
font_size = 1500
XMIN = -1000
YMIN = -2000
XMAX = 10000
YMAX = 20000
o = 500
l = 1000
r = 1500
y1 = YMAX + o
y2 = y1 + 2 * l
y3 = y2 + l
y4 = y3 + l
yc = y4 + r
# x_grid_group.addObject(x_sketch)
def create_x_grid(sketch, xcoord, text):
    g = Part.makeLine(FreeCAD.Vector(xcoord, YMIN, 0), FreeCAD.Vector(xcoord, YMAX, 0))
    Part.show(g)
    # x_grid_group.addObject(g0)
    g1 = sketch.addGeometry(Part.LineSegment(FreeCAD.Vector(xcoord, y1, 0), FreeCAD.Vector(xcoord, y2, 0)))
    g2 = sketch.addGeometry(Part.LineSegment(FreeCAD.Vector(xcoord, y2, 0), FreeCAD.Vector(xcoord, y3, 0)))
    g3 = sketch.addGeometry(Part.LineSegment(FreeCAD.Vector(xcoord, y3, 0), FreeCAD.Vector(xcoord, y4, 0)))
    g4 = sketch.addGeometry(Part.Circle(App.Vector(xcoord, yc, 0), App.Vector(0, 0, 1), r), False)
    t = Draft.makeText(text, App.Vector(xcoord, yc - font_size / 3, 0))
    t.ViewObject.FontSize = font_size
    t.ViewObject.Justification = 'Center'
    # x_grid_group.addObject(t)
    sketch.addConstraint(Sketcher.Constraint('DistanceX', g1, 1, xcoord))
    sketch.addConstraint(Sketcher.Constraint('DistanceY', g1, 1, y1))
    sketch.addConstraint(Sketcher.Constraint('Coincident', g1, 2, g2, 1))
    sketch.addConstraint(Sketcher.Constraint('Coincident', g2, 2, g3, 1))
    sketch.addConstraint(Sketcher.Constraint('Vertical', g1))
    sketch.addConstraint(Sketcher.Constraint('Vertical', g3))
    sketch.addConstraint(Sketcher.Constraint('Radius', g4, r))
    sketch.addConstraint(Sketcher.Constraint('PointOnObject', g3, 2, g4))
    sketch.addConstraint(Sketcher.Constraint('Perpendicular', g4, g3))
def create_grids(coords, texts, sketch, direction='x'):
    if direction == 'x':
        # x_circles_vertex_numbers = []
        # i = 1
        for coord, text in zip(coords, texts):
            # x_circles_vertex_numbers.append(i * 7)
            create_x_grid(sketch, coord, text)
            # i += 1
    elif direction == 'y':
        # y_circles_vertex_numbers = []
        # i = 1
            y_circles_vertex_numbers.append(i * 7)
            # create_x_grid(sketch, coord, text)
            # i += 1
    doc.recompute()
doc = App.newDocument("grid")
# x_grid_group = doc.addObject("App::DocumentObjectGroup", "x_grid")
x_sketch = doc.addObject('Sketcher::SketchObject', 'x_sketch')
create_grids([0, 500, 5000], ['A', 'B', 'C'], x_sketch)
# sketch.addConstraint(Sketcher.Constraint('Coincident',i+3,2,i+4,1))
ebrahim raeyat
Postby ebrahim raeyat » Fri Sep 27, 2019 1:19 pm
yes, it works and thanks a lot, i examined that, but i think when i want to export that to pdf or dxf it is time consuming for exporting a letter shape, isn't it? or this is the best solution? thanks.
Postby chrisb » Fri Sep 27, 2019 4:24 pm
If you don't use PartDesign, you can use Expressions for the Placement of the Letters. Besides that, just try if it is too time consuming, or as we say in FreeCAD: "It's done when it's done".
Postby chrisb » Fri Sep 27, 2019 5:03 pm
For my taste there are too many degrees of Freedom. Here is how I would do it outside of PartDesign (Letter C only):
movingText.FCStd
(7.11 KiB) Downloaded 2 times
ebrahim raeyat
Postby ebrahim raeyat » Sat Sep 28, 2019 7:15 am
Thanks. I apply expression, but it did not work.
when i apply it in model, it did not give me an error but when i move circle, it gives me this error:
>>> t.setExpression('.Placement.Base', 'x_sketch.Geometry[3].Location')
>>> doc.recompute()
1
<Exception> Property '' not found
in property binding 'Placement'
Recompute failed! Please check report view.
this is how i use it in script:
t.setExpression('.Placement.Base', f'{sketch.Name}.Geometry[{i}].Location')
complete file:
import Sketcher
import FreeCAD
import Part
import Draft
font_size = 1500
XMIN = -1000
YMIN = -2000
XMAX = 10000
YMAX = 20000
o = 500
l = 1000
r = 1500
y1 = YMAX + o
y2 = y1 + 2 * l
y3 = y2 + l
y4 = y3 + l
yc = y4 + r
no_of_edge_in_on_axis = 4
def create_x_grid(sketch, xcoord, text, i):
    Part.show(g)
    t = Draft.makeText(text)  # , App.Vector(xcoord, yc - font_size / 3, 0))
        i = no_of_edge_in_on_axis - 1
            create_x_grid(sketch, coord, text, i)
            i += no_of_edge_in_on_axis
            # y_circles_vertex_numbers.append(i * 7)
    doc.recompute()
ebrahim raeyat
Postby ebrahim raeyat » Sat Sep 28, 2019 7:48 am
very thanks. it is exactly what i want. Thanks.
Postby chrisb » Sat Sep 28, 2019 8:50 am
Glad to help. As you can see, I gave names to the dimensions, which made it easy to reference them.
