[Solved] Change hole(s) from top to bottom
IngoMeier
Postby IngoMeier » Mon Sep 30, 2019 8:25 pm
sorry, but I couldn't find the right solution in the wiki and via the search:
I want to change/move existing holes from top to Botton.
I have an object (the sample shows only one hole) with many threaded holes from top. Now these threaded holes Need
to be moved from top to bottom with thread removed and countersink added.
Shouldn't this work somehow via "map reversed"?
Thank you very much for any hint in advance!
Best regards,
Ingo
OS: Windows 7
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Hole_Top_Bottom.FCStd
(13.33 KiB) Downloaded 12 times
Re: Change hole(s) from top to bottom
Postby chrisb » Mon Sep 30, 2019 9:22 pm
I'm pretty sure there is already a ticket.
freedman
Postby freedman » Tue Oct 01, 2019 4:01 am
This issue might be handled best using datum planes. If you place a sketch or multiple sketches on a datum plane then it can be attached to different faces. Datum planes can also be reversed on a face.
papyblaise
Postby papyblaise » Tue Oct 01, 2019 5:49 am
Hello
Miror works parfectly if you Pad "Midplan" because miror make a mirored figur from the medium plane (here XY)
Miror hole.PNG (37.3 KiB) Viewed 334 times
IngoMeier
Postby IngoMeier » Tue Oct 01, 2019 3:05 pm
Hi Papyblaise,
thank you very much for the hint!
I just changed:
in the Hole:
- Midplane from false to true
- Reversed from false to true
in the Sketch:
- adjust the Z Position of the Attachment
Simple and easy solution!
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 02, 2019 5:52 pm
mirroring is not a good construction it is a Laisy use
the midplane workaround is a good solution to get double cones
Postby chrisb » Thu Oct 03, 2019 8:40 am
Can you please elaborate? The mirror is fully parametric and easy to use. Why not use it?
