trying to draw a line along the face of a cylinder
sebastia
Postby sebastia » Tue Oct 01, 2019 7:47 pm
Hi! i am trying to draw a line along the face of a cylinder but i can't seem to get it to work. whenever i draw a line it goes through the cylinder instead of along the face. Any suggestions or help would be greatly appreciated.
Re: trying to draw a line along the face of a cylinder
Postby chrisb » Tue Oct 01, 2019 9:41 pm
Hi and welcome to the forum!
The information you gave is a bit sparse. It would help to know which workbench you use and your final goal would be interesting too.
sebastia
Postby sebastia » Wed Oct 02, 2019 3:54 pm
HI, i orignally drew the cylinder in the parts workbench. the end result is suppose to be a cylinder with a row of knives attached to the outside of the cylinder at an angle. imagine a 55 gallon drum with knives poking out in a diagonal pattern across the surface of the drum.
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 02, 2019 5:10 pm
hi use a Datum plain position
i guess you like to be it tangentional on the cylinder surface
a image on what you are on woudt be better then many words
papyblaise
Postby papyblaise » Wed Oct 02, 2019 5:59 pm
Hello
I suppose as you need to do a sorte of malaxer for concret, whith a helicoidal plate of metal around the internal surface of the drum
In this case do it whith a addpipe along an helix by path
sebastia
Postby sebastia » Wed Oct 02, 2019 7:01 pm
Thanks for the input i will try that. im new to this, ill work on taking a screenshot and posting it.
sebastia
Postby sebastia » Wed Oct 02, 2019 7:34 pm
So this is a picture of my cylinder. i was able to wrap a helix around where i wanted to draw the lines. is there anyway to do that?
Trash drum 1.1.FCStd
(17.55 KiB) Downloaded 14 times
GlouGlou
Postby GlouGlou » Wed Oct 02, 2019 8:18 pm
This is what I understood. Check it out. ;)
Trash drum GG.FCStd
(14.74 KiB) Downloaded 4 times
sebastia
Postby sebastia » Wed Oct 02, 2019 8:41 pm
Yeah that looks right. i dont want to have the helix just a line.
freedman
Postby freedman » Thu Oct 03, 2019 4:04 am
This is one of those situations where I do some things outside of Part Design. I made the helix in Part and the array in Draft. I made the pad sketch a bit smaller than the helix so the lines are easier to see.
cyl_line.FCStd
(11.23 KiB) Downloaded 4 times
