trying to draw a line along the face of a cylinder
Hi! i am trying to draw a line along the face of a cylinder but i can't seem to get it to work. whenever i draw a line it goes through the cylinder instead of along the face. Any suggestions or help would be greatly appreciated.
Re: trying to draw a line along the face of a cylinder
Hi and welcome to the forum!
The information you gave is a bit sparse. It would help to know which workbench you use and your final goal would be interesting too.
HI, i orignally drew the cylinder in the parts workbench. the end result is suppose to be a cylinder with a row of knives attached to the outside of the cylinder at an angle. imagine a 55 gallon drum with knives poking out in a diagonal pattern across the surface of the drum.
- pl7i92LCNC
hi use a Datum plain position
i guess you like to be it tangentional on the cylinder surface
a image on what you are on woudt be better then many words
- papyblaise
Hello
I suppose as you need to do a sorte of malaxer for concret, whith a helicoidal plate of metal around the internal surface of the drum
In this case do it whith a addpipe along an helix by path
Thanks for the input i will try that. im new to this, ill work on taking a screenshot and posting it.
So this is a picture of my cylinder. i was able to wrap a helix around where i wanted to draw the lines. is there anyway to do that?
- Trash drum 1.1.FCStd
- (17.55 KiB) Downloaded 31 times
This is what I understood. Check it out.
- Trash drum GG.FCStd
- (14.74 KiB) Downloaded 23 times
- Capture.PNG (73.02 KiB) Viewed 1133 times
Yeah that looks right. i dont want to have the helix just a line.
This is one of those situations where I do some things outside of Part Design. I made the helix in Part and the array in Draft. I made the pad sketch a bit smaller than the helix so the lines are easier to see.
- cyl_lines.JPG (54.83 KiB) Viewed 1091 times
- cyl_line.FCStd
- (11.23 KiB) Downloaded 29 times
