Tools > Save picture... returns a blank (white) PNG image
JiriVALASEK
Postby JiriVALASEK » Wed Oct 02, 2019 9:43 am
I am having difficulties saving a picture using "Tools > Save picture.." utility. I did follow several threads trying to solve it, but nothing worked.
The threads I've already read: Trial 1: User parameter:BaseApp/Preferences/View/SavePicture ='' > blank image
Trial 2: User parameter:BaseApp/Preferences/View/SavePicture ='FramebufferObject' > blank image
Trial 3: User parameter:BaseApp/Preferences/View/SavePicture ='PixelBuffer' > blank image
Trial 4: User parameter:BaseApp/Preferences/View/SavePicture ='CoinOffscreenRenderer' >
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
freecad: ../../src/xcb_io.c:259: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
Aborted (core dumped)
Tested with:
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Qt version: 5.9.5
*both versions installed using PPA and Apt-get.
GPU: Intel® HD Graphics 520 (Skylake GT2)
$ lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
Subsystem: Lenovo Skylake GT2 [HD Graphics 520]
Kernel driver in use: i915
Kernel modules: i915
Has anyone found a solution to this problem?
Thanks a lot.
Site Admin
Re: Tools > Save picture... returns a blank (white) PNG image
Postby wmayer » Wed Oct 02, 2019 10:16 am
I am running
OS: Ubuntu 18.04.3 LTS (XFCE/xubuntu)
Version: 0.19.18357 (Git)
Build type: Unknown
Hash: 19ac3ecfc7ba4f76089b96b54dfae4bfb0667c5b
Qt version: 5.9.5
under VirtualBox with lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: InnoTek Systemberatung GmbH VirtualBox Graphics Adapter
Kernel driver in use: vboxvideo
Kernel modules: vboxvideo
00:03.0 Ethernet controller: Intel Corporation 82540EM Gigabit Ethernet Controller (rev 02)
And for me SavePicture ='', SavePicture ='FramebufferObject' and SavePicture ='PixelBuffer' works. Only using 'CoinOffscreenRenderer' raises an error.
JiriVALASEK
Postby JiriVALASEK » Wed Oct 02, 2019 11:17 am
Now I tried
OS: Linux
Version: 0.18.16093 (Git)
Build type: Unknown
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.12
OCC version: 7.0.0
*installed using snap install freecad.
It started with a warning:
(process:2653): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
and the results were:
Coin warning in SoGLLineWidthElement::updategl(): 10.000000 is outside the legal range of [1.000000, 7.375000] for this OpenGL implementation's glLineWidth() settings. It was now clamped.
See the documentation of SoGLLineWidthElement for information on how the application programmer should acquire the boundary values for the legal range.
Trial 2: User parameter:BaseApp/Preferences/View/SavePicture ='FramebufferObject' > correct image
Trial 3: User parameter:BaseApp/Preferences/View/SavePicture ='PixelBuffer' > correct image
[xcb] <unknown exception traceback><type 'exceptions.RuntimeError'>: Offscreen rendering failed
Problem is that I am unable to add my workbench and a necessary python module (pyPNG) into this installation.
  • The home dir for it is /snap/freecad/8/opt/local/FreeCAD-0.18/ and /snap/freecad/8/opt/local/FreeCAD-0.18/Mod is Read-only and so it won't allow me to copy a workbench folder into it.
  • Python modules installed using pip (pip install <module> or python -m pip install <module>) aren't present in this FreeCAD ( as they are in any FreeCAD from PPA).
Any ideas about those issues?
EDIT
I managed to add my workbench - I put it inside ~/snap/freecad/8/.FreeCAD/Mod and I found out that PySide2 is missing in this installation.
openBrain
Postby openBrain » Wed Oct 02, 2019 1:00 pm
IMO just the known problem with Qt5 along with Intel GFX... ;)
Qt5.12.1 has solved the problem in most cases for Windows users.
You can find several threads in the forum about that.
Generally, this issue also affects the Print function.
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 02, 2019 1:45 pm
the freecad daily does have suport for qt5 and brings in the miissing
you shoudt update at 18.04 to the new 0,19
JiriVALASEK
Postby JiriVALASEK » Wed Oct 02, 2019 7:22 pm
I have tried that, it did not work.
JiriVALASEK
Postby JiriVALASEK » Wed Oct 02, 2019 7:29 pm
Hi, I know that it's a problem with Qt5 and Intel GPU.
I don't have any problems on a Windows PC, but I need to use Ubuntu.
I found those multiple threads but none of them yielded a solution, that's why I asked if anyone found a solution...
