Part -> sweep
baltic
Part -> sweep
Postby baltic » Sun Oct 06, 2019 6:53 pm
Why is it not possible to sweep S004 along S005?
TL;DR for some1 who googles this:
The sketch is not shown in the Part -> Sweep choice list because the tool doesn't work with sketches with holes in them.
Use Part Design sweep tool. Be sure, that the sweep path is outside of the resulting sweep figure.
OS: Ubuntu 18.04.3 LTS
Version: 0.18.16131 (Git) AppImage
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.7
Qt version: 5.6.2
test.FCStd
(49.2 KiB) Downloaded 15 times
papyblaise
Re: Part -> sweep
Postby papyblaise » Sun Oct 06, 2019 8:18 pm
Hello
Because the radius r3mm of S005 is too small
baltic
Re: Part -> sweep
Postby baltic » Sun Oct 06, 2019 9:11 pm
No, you can't even select the S004 in the list of Part -> sweep tool. Much before you can get to s005
Re: Part -> sweep
Postby chrisb » Sun Oct 06, 2019 11:46 pm
The error message is
31.3526 <App> Document.cpp(3455): Failed to recompute test#AdditivePipe: BRepAdaptor_Curve::No geometry
Re: Part -> sweep
Postby chrisb » Sun Oct 06, 2019 11:48 pm
If I start with a radius of 30 and reduce it (stepwise) to 3mm it works.
test_cb.FCStd
(67.93 KiB) Downloaded 11 times
baltic
Re: Part -> sweep
Postby baltic » Mon Oct 07, 2019 8:28 am
But you did it with Part Design, not Part. Would be interesting how you did it with part design, coz that one always crashes for me on the model.
And the question still stands, why is it not shown in the list of Part -> Sweep?
pl7i92LCNC
Re: Part -> sweep
Postby pl7i92LCNC » Mon Oct 07, 2019 8:56 am
hi with the Appimage it workes on 30mm
test_PL.FCStd
(86.77 KiB) Downloaded 10 times
Re: Part -> sweep
Postby chrisb » Mon Oct 07, 2019 9:15 am
1) you should not use sketches from inside of a body in any Part operation
2) Part->Sweep cannot use sketches with an inner closed path.
papyblaise
Re: Part -> sweep
Postby papyblaise » Mon Oct 07, 2019 11:04 am
If you need use Partdesign you have tochange r3 to r3.01mm mini (see pipe in one)
If you need use PartWb you have to bdo 2 separate sketches : one for external , one for internal and subtract booleen (see pipe in two)
but the question is why start to us Partdesign and continu whith PartWb , very bad idee
piping.FCStd
(91.39 KiB) Downloaded 11 times
baltic
Re: Part -> sweep
Postby baltic » Mon Oct 07, 2019 11:46 am
Thats not true, since it doesnt work either way. Outside or inside.
Yeah, thats actually true. I have tested it on a simple case.
Thanks
Ok so the answer to the original question is:
Part -> sweep cannot use sketches with an inner closed path.
