A sketch scaling
pl7i92LCNC
Re: A sketch scaling
Postby pl7i92LCNC » Mon Oct 07, 2019 2:52 pm
her is the file
i hat to clean up the JPG to get a full size mouse
mouse2.svg
(26.22 KiB) Downloaded 8 times
mouse2.FCStd
(120.33 KiB) Downloaded 8 times
koluna
Postby koluna » Mon Oct 07, 2019 2:59 pm
pl7i92LCNC wrote:
Mon Oct 07, 2019 2:36 pm
as i did show in the Video
you need AFTER the vectorise to get the 2 Views seperated
thne delete the original RIGHT MOUSE Click
I saw the second video twice.
I removed the original image. So the vectorized image left only.
The SVG file was very fine. But when I opened it in FC the result was wrong. Some parts were filled.
if it showes Filling and Contour its the Vector
if it does not its the image to be deleted
then Click again Right on the Vector
FILLING and Contour
X at Filling
and First low on contour
done export as standard svg
Sorry, I did not understand you :(
koluna
Postby koluna » Mon Oct 07, 2019 3:13 pm
My actions at the video: https://yadi.sk/i/N7UqD47jjbL9HQ
koluna
Postby koluna » Mon Oct 07, 2019 3:52 pm
FILLING and Contour
X at Filling
I understood you now, thanks. I removed the fill. It works :)
freedman
Postby freedman » Mon Oct 07, 2019 5:19 pm
You can get a good offset using "make a thick solid" (see pic) in Part design. If you then select the offset line and do some magic (probably in Part) you could get an offset sketch.
freedman
Postby freedman » Mon Oct 07, 2019 7:56 pm
I don't have all the details but I took the original and downgraded it a couple times in Draft and then converted to skech. I did in fact get an offset of the original and now have a sketch I can use in Part design. No parametrics of coarse but I could use it to make a lid.
koluna
Postby koluna » Tue Oct 08, 2019 6:18 am
What magic did you mean? :)
pl7i92LCNC
Postby pl7i92LCNC » Tue Oct 08, 2019 10:36 am
kolona if you tell us what kind of baking mold you woudt like to see we cen do some more magic for you
so i guess you are on the right way to do it as you now can get outlines and offsets
if thickness does not work you can use sketch from face and do a offset there
make a pad out of it and boolen it out
koluna
Postby koluna » Tue Oct 08, 2019 4:50 pm
My goal is to make some shapes for biscuits...
I get pictures from the internet and make my shapes :)
It looks like this (see attachment).
I am studying Inkscape now to prepare SVG files.
By the way... Thickness tool does not work with a solid in my file...
pl7i92LCNC
Postby pl7i92LCNC » Tue Oct 08, 2019 6:34 pm
this woudt be better to do it in Blender3D
its a simple use of the svg path to get edges up
