Thanks. I will study your link.
I converted my contour to Sketch (with a tool of Draft) and deleted some self-intersection (they were!).
Further, I tried to use Part Sweep with this edited Sketch. FC crashed...
Further, I tried to convert Sketch to Draft (Sketch002) and tried to use Part Sweep with this path. FC crashed...
I checked my paths and did not find out any intersection, but FC crashes...
You missed the point. Selfintersection is not inside the sketch but in the resulting sweep geometry. This happens with tight internal arcs and long internal sections of the sweep profile.
kisolre wrote: ↑Wed Oct 09, 2019 8:50 pm
I reduce the bottom edge in Sketch001. FC crashes...
I deleted sharp corners at feet and tried again. FC crashes...
Where are they?
I cannot find out they.
pl7i92LCNC wrote: ↑Wed Oct 09, 2019 7:21 pm
the path has lots of intersection
jo can see it on the GREEN lines that are very tight at this intersections
need manuell tweeking
its all about the SVG
you need to get better path from inkscape
or even a higher reulutionfrom GIMP
i do(DID till im Fierd) lots of stuff every day on this and the image is the GOAL to get best parts http://schwedenfeuer.de/feuersauelen.htm SCROLL DOWN all from a image to CUTTER
a "cleaner" path use import to get it hooked up
the FC file is to large to be uploaded
tweek the path
first make it a Sketch with DRAFT BLUE/RED icon
then in sketcher see the problem the RIGHT massiv green there are 2 points move them outwards
BUT you will not see this at all as the MAIN Image is right look here Video at 1:50 cleaning the Image for Path
You speak about a self-intersection in Path (Sketch). Am I right? I corrected it.
I asked about a self-intersection in a result geometry that is got after the Sweep tool.
I am sorry if I did not understand you...
