Part->Chamfer does not work
koluna
Re: Part->Chamfer does not work
Postby koluna » Thu Jan 09, 2020 6:18 pm
Roy_043 wrote:
Thu Jan 09, 2020 5:13 pm
You may have posted in the wrong topic as you are using the Part Design WB.
I am sorry...
PartDesign_Chamfer seems sensitive to the selection order of the edges?
Not for me...
If I first select Edge26 and then the other edges in a CCW order the command works OK.
It does not work for me...
It is not sensitive to the selection order...
My version is "Version: 0.19~pre2~201912181405~ubuntu16.04.1".
What is wrong?
Postby chrisb » Thu Jan 09, 2020 8:30 pm
You posted sort of to the right topic, because you used a Part chamfer, but that is another mistake. You should have used the PartDesign chamfer (preferred) or you should have used the body and not the contained feature for chamfering.
What is wrong?
The real problem is that the lines are not really tangent, but almost. Please retry with all connections being tangent.
Roy_043
Postby Roy_043 » Thu Jan 09, 2020 8:54 pm
As already mentioned: I am able to PartDesign_Chamfer the required edges. It is true that the arcs are non-tangential, but that may be design intent.
nut2_Chamfer.FCStd
(64.07 KiB) Downloaded 4 times
Postby chrisb » Thu Jan 09, 2020 10:38 pm
It is known that this intent conflicts on the OCC side with angles very close to 180°.
koluna
Postby koluna » Fri Jan 10, 2020 7:20 am
The theme does not match the content. A bit :) Sorry.
I use only Part Design in this project.
I use the Part Design chamfer.
I am scared... I think that it will be difficult :(
koluna
Postby koluna » Fri Jan 10, 2020 7:27 am
I see your file, thanks. But it does not work for me... :(
koluna
Postby koluna » Fri Jan 10, 2020 7:28 am
And? What can we do?
koluna
Postby koluna » Fri Jan 10, 2020 7:30 am
What a shame... What is it?!
Postby chrisb » Fri Jan 10, 2020 9:32 am
Nothing.
My attached file has all tangents. Please note that the points don't lie anymore on the inner construction circle.
nut2_cb.FCStd
(37.37 KiB) Downloaded 7 times
koluna
Postby koluna » Sun Jan 12, 2020 2:13 pm
Hi, guys!
Thanks a lot! I have already did it! :)
nut2.FCStd
(59.81 KiB) Downloaded 3 times
