Sketch points arcs and lines selection issues
callisto
Postby callisto » Thu Oct 10, 2019 12:40 pm
Hi FreeCAD forum,
I am having problems during Sketch design.
In the past I used an early 0.18 and it was right no issues, and I made lot of parts.
At some point this yeas suddenly 0.18 started working with strange behaviour.
If I try to select lines, arc and points to be able to constraint them, I have to point precisely the mouse otherwise there is no chance to select something.
I improved a little bit by disabling the "Drag Performance" checkbox, which allows me to select the lines with better luck.
Using one 0.19 I got the same behaviour.
also on the Menu Preferences, at Sketch tab, the Show Grid doesn't seem working because I see the grid all the time and Show Grid is stuck on the screen. and Snap Grid I always set to Off.
The screen is a high resolution Dell laptop but I don't see any improvements if I change the App DPI settings for FreeCAD.
it is the most difficult challenge ever seen on a CAD... selecting parts!!!!.
Do you ever experienced this issue before, please?
thanks.
Callisto.
OS: Windows 10 (10.0)
Version: 0.19.18024 (Git)
Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
Python version: 3.6.8
Qt version: 5.12.1
callisto
Re: Sketch points arcs and lines selection issues
Postby callisto » Thu Oct 10, 2019 12:48 pm
I post the link at the image:
https://pasteboard.co/IBkcMnH.jpg
pl7i92LCNC
Postby pl7i92LCNC » Thu Oct 10, 2019 1:12 pm
a good advice is always to get the main center it will grap it within 0,2mm Yellow Dot marked
but as it troubles grap your sketch move slightly and do a point constrain this will shure grap the center point point sketch point first selection
