offset2D no OK button
pl7i92LCNC
Postby pl7i92LCNC » Thu Oct 10, 2019 5:33 pm
hi
i did today offset a wire and cand press the OK button did i miss somthing
Workflow A Draft
1 Select wire in Draft hit Offset
in the side menue Value
OCC Copy
but no OK
workflow Part
select the wire hit Part offset2D
Shoot down off the Appimage
What workes is the Scripting
as shown here
https://www.freecadweb.org/wiki/Part_Offset2D
this made the trick
f = App.ActiveDocument.addObject("Part::Offset2D", "Offset2D")
f.Source = App.activeDocument.getObjekt("Wire") #some object
f.Value = 4.0
BUT i got to Manuell recompute the Offest2D
Roy_043
Re: offset2D no OK button
Postby Roy_043 » Thu Oct 10, 2019 6:20 pm
The Draft Offset task panel indeed does not have an OK button. You either click in the 3D view or enter the offset distance manually and then press Enter.
Part Offset2D is a different command. Its task panel does have an OK button.
Postby chrisb » Thu Oct 10, 2019 6:30 pm
You can do the recompute from the script as well.
DeepSOIC
Postby DeepSOIC » Thu Oct 10, 2019 7:01 pm
workflow Part
Sounds like computing 2d offset with the default value (1 mm) crashes FreeCAD. Looks like we need some way to disable the preview for these situations.
EDIT: would you mind writing a bug report? It will also be handy if you upload the shape you're trying to offset.
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 11, 2019 6:36 am
Hi Tanks for the Help
its a Bspline Bziercurve i guees ass a SVG import that is to be offsetet
dino_offset.FCStd
(65.79 KiB) Downloaded 8 times
