Dependency graph fails when using formula in attachment offset?
Roy_043
Postby Roy_043 » Fri Oct 11, 2019 10:55 am
I have come across a situation where using a formula in the attachment offset of a sketch results in a dependency graph failure.
I wonder if I am doing something wrong or if this is perhaps a bug or a known issue.
Test:
  1. Open the attached file.
  2. Create a dependency graph: OK.
  3. Change the Attachment Offset X value of Sketch004 (Label=WindowOutline). Use this formula: Sketch001.AttachmentOffset.Base.x
  4. Create a dependency graph: Fail.
OS: Windows 8.1 (6.3)
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.6.8
Qt version: 5.12.1
WindowSill.FCStd
(30.98 KiB) Downloaded 8 times
kisolre
Re: Dependency graph fails when using formula in attachment offset?
Postby kisolre » Fri Oct 11, 2019 11:38 am
No problem here:
Qt version: 5.12.1
What is your Graphviz version? I think I am using graphviz-windows_2.41.81.
Postby chrisb » Fri Oct 11, 2019 1:12 pm
To find out call the program "dot" from the graphviz package with the parameter "-v".
Roy_043
Postby Roy_043 » Fri Oct 11, 2019 2:10 pm
Thanks for your answers. On the download page I find that I am using the current stable Windows version: 2.38. Maybe @kisolre is using a dev version?
It is a strange problem anyway, because after continuing to work with the file the problem mysteriously seems to go away. See the attached file.
WindowSill_001.FCStd
(34.8 KiB) Downloaded 4 times
vocx
Postby vocx » Fri Oct 11, 2019 3:39 pm
Thanks for your answers. On the download page I find that I am using the current stable Windows version: 2.38. Maybe @kisolre is using a dev version?...
In Ubuntu 18.04
dot -v
dot - graphviz version 2.40.1 (20161225.0304)
This tells me that version 2.40 was released back in 2016. And Ubuntu is known for having old packages. Probably there is an even newer version right now. If I may guess, I'd say the version 2.38 that you reference is quite old.
Postby chrisb » Fri Oct 11, 2019 4:44 pm
2.38 was known to show problems. If you cannot upgrade, you should downgrade to 2.36.
Roy_043
Postby Roy_043 » Fri Oct 11, 2019 5:47 pm
Apparently development is at 2.43, But the official Windows version is stuck at 2.38. I am unable to find 2.36.
UR_
Postby UR_ » Fri Oct 11, 2019 6:00 pm
latest windows build: https://ci.appveyor.com/api/buildjobs/k ... indows.zip
Roy_043
Postby Roy_043 » Fri Oct 11, 2019 6:53 pm
Thanks. But I still get the error.
Note: Where I said "Sketch004 (Label=WindowOutline)" in the OP, I should have said "Sketch002 (Label=WindowOutline)". This may have confused the issue.
