Error in Mirror if contents are not visible
Postby chrisb » Sun Oct 13, 2019 10:02 pm
I have created a complicated body which I have mirrored completely in Part workbench. If no feature is visible in the body, then the mirror fails with the message
5.6e-08 <App> Document.cpp(3462): Failed to recompute emptyMirror#Part__Mirroring: Cannot mirroR empty shape
Recompute failed! Please check report view.
File is attached.
It used to work in:
OS: macOS High Sierra (10.13)
Version: 0.19.17681 (Git)
Hash: e94af7ff5e873f263cac51d7d47df68eca183250
Python version: 3.7.3
Qt version: 5.9.7
It is not working in:
Version: 0.19.18524 (Git)
Hash: bea009c1d52b97655dab2d5c0fbddec30989a902
Qt version: 5.12.5
emptyMirror.FCStd
(11.7 KiB) Downloaded 21 times
bejant
Re: Error in Mirror if contents are not visible
Postby bejant » Mon Oct 14, 2019 6:32 pm
I don't know if this is related or not, but when I open your file I see this in the Report View:
Thread size out of range
No extension found of type 'PartGui::ViewProviderAttachExtension'
And "Body (Mirror #1)" has the white-exclamation-point-in-red-circle error icon in the history tree.
OS: Ubuntu 16.04.6 LTS
Version: 0.18.1.
Python version: 2.7.12
Postby chrisb » Mon Oct 14, 2019 8:21 pm
"No extension found ..." comes from some extension during the 0.19 development cycle.
I have no Idea where the "Thread size" message comes from. I don't see it here. I see it regularly if I use Fasteners. But that's not used here at all.
Do you have Fasteners installed?
Postby chrisb » Mon Oct 14, 2019 8:26 pm
I uninstalled fasteners and still don't see the messages.
DeepSOIC
Postby DeepSOIC » Mon Oct 14, 2019 9:17 pm
Seems like a bug in Part.getShape, as Shape property of Body still gives the correct shape. Interestingly, the outcome also depends on if Body is in Through or Tip display mode: if in Tip, the mirror works, BUT, the body can't be made visible.
DeepSOIC
Postby DeepSOIC » Mon Oct 14, 2019 9:30 pm
The interesting stuff appears to be happening in _getTopoShape() routine found in PartFeature.cpp.
The problem is, it's :shock: :shock: :shock: :shock: long. And complicated.
realthunder
Postby realthunder » Tue Oct 15, 2019 4:57 am
PR submitted here.
hammax
Postby hammax » Tue Oct 15, 2019 5:45 am
… I remade the "complex body" also in PartWB and this time the original Mirror-Part becomes visible
- without mirroring the PartWB-Body.
- perhaps it was only lonely!
emptyMirror_2.FCStd
(18.91 KiB) Downloaded 11 times
Postby chrisb » Tue Oct 15, 2019 9:08 am
Can you upload that file please?
DeepSOIC
Postby DeepSOIC » Tue Oct 15, 2019 12:01 pm
PR submitted here.
Thanks!!
