Draft Workbench - why is my pattern so faint?
rhombus
Postby rhombus » Mon Oct 14, 2019 7:03 pm
Another beginner question. I'm following the tutorial in the Manual: Traditional 2D drafting https://www.freecadweb.org/wiki/Manual: ... D_drafting.
When I try to set a pattern following the instructions, the resulting pattern appears to be very faint. Compare the image in the tutorial with my screenshots:
Any idea what might be going on here?
I've also attached the FreeCAD file for reference
2d_drafting_tutorial.FCStd
(17.04 KiB) Downloaded 12 times
Roy_043
Re: Draft Workbench - why is my pattern so faint?
Postby Roy_043 » Tue Oct 15, 2019 7:38 am
Your Pattern Size is 0.05. In the tutorial it is 0.005.
Before changing this value you may need to change your Units settings:
Menu > Edit > Preferences... > Click on General in the left bar > Activate the Units tab > Change the number of decimals to a higher value.
Roy_043
Postby Roy_043 » Tue Oct 15, 2019 8:05 am
I seem to remember a discussion about the "Number of decimals" setting and how it should not restrict user input (as it does here*). I cannot find it now. Was a conclusion ever reached?
* If the number of decimals is 2 the user cannot enter 0.005 for the Pattern Size.
pl7i92LCNC
Postby pl7i92LCNC » Tue Oct 15, 2019 12:12 pm
this is how the people how make things like that shoudt konsidder in first place
please mark the tread as solved
if it is posible give the ttread a Patternsize in name
DeepSOIC
Postby DeepSOIC » Tue Oct 15, 2019 1:38 pm
I remember there was at least one such discussion, probably more than one. Couldn't find it either.
I recommend setting precision to 8 decimals (8 because it's enough to be within standard tolerance of 1e-7 mm after rounding). Sure it may look ugly, but at least it should prevent nasty surprises.
rhombus
Postby rhombus » Tue Oct 15, 2019 1:55 pm
Hi Roy -- thanks for your reply and the hint; before posting I'd already tried adjusting the precision (and entering 0.005 as the pattern size) and it only makes the display issue worse:
I don't understand what the pattern size means. Is it the spacing between the lines?
rhombus
Postby rhombus » Tue Oct 15, 2019 1:57 pm
Thanks for the hint. As I've written in my reply to Roy, increased precision doesn't resolve the issue. I can enter 0.005, but the problem only gets worse.
rhombus
Postby rhombus » Tue Oct 15, 2019 2:37 pm
Okay, something isn't right with my display.
Proceeding with the same tutorial, I made the arc for the door. The tutorial doesn't mention this, but clearly, the arc uses a dashed line, so that's what I set.
Here's the original arc (selected), draw style set to 'Solid':
Here's the arc with the draw style set to 'Dashed':
Is this caused by some view setting? Or is it a driver problem?
Roy_043
Postby Roy_043 » Tue Oct 15, 2019 5:05 pm
You should post your FreeCAD version info (see pink banner).
rhombus
Postby rhombus » Tue Oct 15, 2019 9:21 pm
Sorry, here is my version info:
OS: Gentoo/Linux
Version: 0.18.Unknown
Python version: 3.6.5
Qt version: 5.12.3
