Problem to make complex object
Andri82
Postby Andri82 » Wed Oct 16, 2019 7:28 am
Hello all,
I use Freecad since 2 month ago, I have learned many things, but I have a problem to create a complexe object. I don't know how can I make this object.
I have tested to make a different sketch in different height, and use the button "sweep", but after that I don't know how to continue.
Thank you in advance, and have a good day all.
Re: Problem to make complex object
Postby chrisb » Wed Oct 16, 2019 8:15 am
Hi and welcome to the forum!
It seems you are working in Part workbench. There you can use Draft->Array in its polar form to multiply the pillar.
Andri82
Postby Andri82 » Wed Oct 16, 2019 8:25 am
Yes, but when I have used the array,when pilliar touch an another pilliar, it's not rounded between. I don't know how make this rounded form...
Postby chrisb » Wed Oct 16, 2019 8:37 am
It's not rounded because the pillar doesn't end horizontally.
If the ends of the walls can be rounded you could model the arc instead of the pillar and add fillets.
Andri82
Postby Andri82 » Wed Oct 16, 2019 9:43 am
If you had to make this object, how would you do it ? And how would you do begin
microelly2
Postby microelly2 » Wed Oct 16, 2019 12:47 pm
I use a BSpline surface with a pin and make a transformation of the poles
which maps the rectangle base grid to a arc sector
then apply Draft polar Array
Andri82
Postby Andri82 » Wed Oct 16, 2019 1:14 pm
Hmmm, thank you to your help, but I think that it's a hard method to make my object with your method :shock:
papyblaise
Postby papyblaise » Wed Oct 16, 2019 3:47 pm
Hello
Maybe the best solution is draw only one arche (the grey one) and array 12 times and finish whith the base
crone.FCStd
(418.37 KiB) Downloaded 14 times
hammax
Postby hammax » Thu Oct 17, 2019 5:03 am
… how about that:
Arcade.FCStd
(122.67 KiB) Downloaded 11 times
Andri82
Postby Andri82 » Thu Oct 17, 2019 11:34 am
Thank you PapyBlaise et Hammax, your messages help me a lot ! ;) It's exactly what i need
