Best way for first hand on FreeCAD 0.18 ?
vincen
Postby vincen » Fri Oct 18, 2019 12:13 pm
Hi
I'm just starting with FreeCAD to design my first 3D part to print. Unhappy I discover that the 0.18 version of FreeCAD has been a major change compared to previous versions and most tutorials I can find online are obsolete as based on previous versions of FreeCAD :(
I have checked also here the Wiki and Forum but unhappy not much more useful ! Any advices where I can find that ? or it doesn't exist yet ? and have to use old tutos and find out how to adapt them with new version......
Thanks a lot for help,
Vincèn
pl7i92LCNC
Re: Best way for first hand on FreeCAD 0.18 ?
Postby pl7i92LCNC » Fri Oct 18, 2019 4:36 pm
just walk your way forward
and look at some advice tutorials
use PartDesign for real constructiv parts
and for imple parts bool them together with Part
what kind of prints are you looking for
if you get us here a idee we will guide you
and ofcause any quetion will be answerd
bejant
Postby bejant » Fri Oct 18, 2019 4:58 pm
Hi Vincèn and welcome to the forum! I did a quick search for "YouTube FreeCAD 0.18 tutorial" and that resulted in many hits, and some more video tutorials are listed here:
https://www.freecadweb.org/wiki/Video_tutorials
If you can post a simple hand drawing of what you want to model we can probably help you get started.
vincen
Postby vincen » Fri Oct 18, 2019 6:41 pm
Yep I was planning to use the PartDesign "mode" ;)
I want to design a part that I'm going to mold in Silicone, so basically I need to design the part, "reverse" it or perhaps just cut it in two considering that all volumes are "contained" so perhaps no need to reverse the part for mold print.....
Yep first place I went at but have to keep an eye on really recent ones ;)
Here it is, it's pretty basic design !
Thanks for help ;)
GlouGlou
Postby GlouGlou » Fri Oct 18, 2019 7:45 pm
I'm not sure to understand the drawing very well, but you can start like this:
Choose the main axle of the object. Here can the Z axle.
Then draw a first sketch to make the cylinder. Sketch will be on XY plane.
You need to know the two diameters to constraint the circles.
Select pad to extrude the main body, and enter the right length....
FirstStep.FCStd
(8.57 KiB) Downloaded 81 times
bejant
Postby bejant » Sat Oct 19, 2019 12:41 am
Sorry, but I'm having trouble understanding it too.
pl7i92LCNC
Postby pl7i92LCNC » Sat Oct 19, 2019 10:47 am
hi i think he is looking for somthing like that
TO the trread starter
the ISO Handdrawing is that only MATERIAL is with lines non HOLES
flug.FCStd
(27.1 KiB) Downloaded 84 times
vincen
Postby vincen » Sun Oct 20, 2019 8:54 am
Thanks at all for answers and suggestions ;) and sorry yep for doing drawing in the wrong way :?
@pl7i92LCNC yep you got it, it's exactly the idea, now I need to improve it which should be easier with base done and going to check how you have built it to learn curves of FC ! And then will have to find out how to transform the whole thing in container for a silicon mold :D
vincen
Postby vincen » Sun Oct 20, 2019 4:07 pm
So I continued on your file to adjust size for what I want to get, but I'm killing my head on that simple issue. As I have growed the central part now the side parts are mixed in structure and I'm enable to find what determines their position regarding the tube :(
Thanks
pl7i92LCNC
Postby pl7i92LCNC » Sun Oct 20, 2019 4:41 pm
ther is a SKETCH inside PAD001
just dopple klick on that and you are fine
the Space bar can activate the sketch so you can see where it is located in the 3d view
