How to set a slope of x.x %
I'm using de the Draft Slope tool to build pipe:
https://www.freecadweb.org/wiki/Draft_Slope
However, I didn't find how to set a slope between two round values in % : I mean 0.5% or 2.3% for example.
It's quite strange because it seem possible if you read the wiki page precited.
Any idea to help me?
Re: How to set a slope of x.x %
What is a slope of 5% in degrees? What about 2.3%? What do these numbers indicate?t.lemaitre wrote: ↑Sat Oct 19, 2019 11:08 pm ...
Is 100% equal to 90 degrees? Measuring a slope in percentage may be a convention used in some fields, but it isn't very precise. It should be measured in degrees, or as the tangent of the angle of aperture.
No, it's 45°. The percentage is in a rectangular triangle with one side horizontal and one side vertical the ratio of the length of the vertical line divided by the length of the horizontal line. So it is in fact the tangent function.
It is e.g. used for waste water pipes and it is very very precise. Tell a channel digger to place the tubes at an angle of 0.572939° and he will call you an idiot. Tell him he should have a drop of 1cm per meter is easy to implement.
Ok, now everybody speaks about the same thing : tangent is equal to percent of slope.
So, are you able to set a slope between two round values in % : I mean 0.5% or 2.3% for example?
If yes, I'd like to know how.
Okay, so it has a definition. I wonder why OP doesn't use it then.
You can't set values with 1/1000 precision as the input control is a QDoubleSpinBox that has a decimal precision of 2 (it's the default value in Qt).t.lemaitre wrote: ↑Sun Oct 20, 2019 12:10 pm Ok, now everybody speaks about the same thing : tangent is equal to percent of slope.
As a workaround you can :
1. Hack a file
Go to this file @ this line and add a new line with same indentation with :
self.spinbox.setDecimals(XXX)
This hack will create a permanent change but will (IMO) be overwritten when a new version is available.
2. Hack the GUI
Click on the Draft/SetSlope function to display the slope input field in the Task panel, then enter following in the Python Console :
from PySide import QtCore, QtGui
QtCore.QTimer.singleShot(2500, lambda:QtGui.QApplication.focusObject().setDecimals(XXX))
After validating the 2nd line, you get 2.5 seconds to set the cursor on the slope input field. When delay expires, the precision is changed.
This hack is a single shot one.
I almost never use Draft, so I won't discuss if it's right or wrong that this input field is limited to 2 decimals, if it should be aligned with application decimals, ...
EDIT : if you want same precision as application, use following as 'XXX' value :
App.ParamGet("User parameter:BaseApp/Preferences/Units").GetInt("Decimals")
I tried it and it works! ThanksopenBrain wrote: ↑Sun Oct 20, 2019 5:19 pm 2. Hack the GUI
Click on the Draft/SetSlope function to display the slope input field in the Task panel, then enter following in the Python Console :Where 'XXX' is the decimal precision.Code: Select all
from PySide import QtCore, QtGui QtCore.QTimer.singleShot(2500, lambda:QtGui.QApplication.focusObject().setDecimals(XXX))
