3D Print puzzle
business_kid
3D Print puzzle
Postby business_kid » Wed Oct 23, 2019 2:21 pm
4_Pillar_Verticals.FCStd
(30.89 KiB) Downloaded 17 times
I eventually ended up with the file above as the shape I wanted for my vertical pillars, but I don't think I can 3dprint that, as the bottom end will not build up correctly. If I stand it up, the middle bit suddenly goes out over thin air :oops:, So I got thinking how to reconstruct them so that they would 3d print.
The best idea I had was this
PillarIdea.FCStd
(5.64 KiB) Downloaded 14 times
The sketch tries to show 2 pieces (one in construction geometry) which I would have to glue together as shown for the middle bit to get the 'wrap around' effect I'm looking for. I'd glue full circles on to them, but all this is looking very messy and gluey. The pillars have a 16mm diameter. I'm hoping for a better 3d printable way of doing it.
pl7i92LCNC
Re: 3D Print puzzle
Postby pl7i92LCNC » Thu Oct 24, 2019 3:24 pm
hi why not laying on the back adding some suport and you are fine
business_kid
Re: 3D Print puzzle
Postby business_kid » Thu Oct 24, 2019 3:49 pm
I'm intending to hand the printing out. The support would have to be lined up perfectly. Frankly, I didn't think that idea was a runner. It's one thing doing a bodge job at home, quite another getting some dweeb in a printing house to do it
Re: 3D Print puzzle
Postby chrisb » Thu Oct 24, 2019 4:40 pm
If you want to glue things: why not glue the top cylinder? Make two spikes on the long bars and two holes in the cylinder so that they fit and then you can easily glue them together.
As an alternative you may think about a small flat at the outside and some chamfer so that you can print the way proposed by pl7i92LCNC but without using support. Printers can fairly well print up to an angle of 70° or even 75°. So there will not be much left.
pl7i92LCNC
Re: 3D Print puzzle
Postby pl7i92LCNC » Thu Oct 24, 2019 5:19 pm
a 3D printer is 65 USD Anet style
there is so mutch need in a single household for that kind of mashine
get you one and mak it yourself
if you can stay on PLA material
business_kid
Re: 3D Print puzzle
Postby business_kid » Fri Oct 25, 2019 7:54 pm
there is so much need in a single household for that kind of machine
get you one and make it yourself
Not here in Ireland
That printer(which I'd like a link to, btw) IF they send to Ireland will have a hefty postage/courier charge (slow post takes months; quicker post takes $$; couriers tale $$$$!). ~Then there's 25% import duty into the EU on much stuff, and maybe VAT at point of entry if you're registered for vat, as I once was. Some things get in cheap, some couriers total the bill (article, freight, import duty) and then apply vat, effectively charging VAT twice, and vat on their bill's vat.
Rule #1 on Internet buying here is: Forget the US. It is (or was) cheaper from China.
The house has no need for a 3d printer. We're minimalists. I wouldn't have a scanner (in my printer) except I can't get a steady photo any more with only one hand on the job.
business_kid
Re: 3D Print puzzle
Postby business_kid » Fri Oct 25, 2019 8:11 pm
@chrisb:
I don't want to glue, but I've no way out of it. here's huge long panels for sides & roof getting glued as well, There is going to be an internal frame of 1"×1" planed soft wood, or approx. 19mm². That's what the 90º section out of the pillar is about. So I can glue to that frame, no problem. This is just getting as bad as one of those really messy Airfix kits? Anyone remember those? The worst stuff was the glue - it gassed you, gave you a headache, and melted the plastic :evil:
business_kid
Re: 3D Print puzzle
Postby business_kid » Mon Oct 28, 2019 3:15 pm
Vertical_Pieces.FCStd
(82.29 KiB) Downloaded 37 times
That's the pillars now. I'm going a two-piece route. Does it matter that I have some stray XZ axis showing up all over the place? How did it get there? I can't seem to get rid of it. If it doesn't affect o/p, then it will hardly matter, will it?
Re: 3D Print puzzle
Postby chrisb » Mon Oct 28, 2019 6:04 pm
Go in the tree into Bodies 5, 6, 7, 8 and make the origin invisible.
