and the FINAL
what i did start all over one Sketch profile one contour
i did in DRAFT clone only the BASE 14 times ((Clones only from Base Sketch)) and moved eatch clone up to ponts where the contour changes
then i scaled eatch clone to the contour shape
then i rotated eatch clone acording to the Height of the clone i wanted 90deg in totel at 60mm geigt so factor 1,5 height to rotation
now in PART make a loft from the clones starting base and adding them all failed managed to go until last 3 to first loft
then i did the rest 3 into another loft
and final fused them together
Wollah a nearly perfect contour shaped VASE took in total from start 10h but as you know how to do it it is 20minutes max
Filesize now 300kb
- vase_neu.jpg (21.07 KiB) Viewed 659 times
