2D draft printer calibration
tadinltd
Postby tadinltd » Mon Oct 28, 2019 6:14 am
I use the Draft workbench for simple 2D drawing for paper 2D printing.
Unfortunately I find that the printed size is far from accurate.
My printer is well calibrated with other software (example: PowerPoint), but printing FreeCad is far from calibrated (3-4% error), with different error in X and Y.
I looked for FC 2D print calibration but could not find any.
Is there a way to make 2D Draft printout calibrated?
Thx
Re: 2D draft printer calibration
Postby chrisb » Mon Oct 28, 2019 6:25 am
How do you currently print? If you use TechDraw you can create a pdf which is extremely accurate. However, usually there is a printer setting for automatic scaling, which must be switched off if you want accuracy.
tadinltd
Postby tadinltd » Mon Oct 28, 2019 7:24 am
Thx chrisb.
I run FreeCad 0.17 on Win10 64 Pro.
I print by the simple File-Print command (with or without preview).
I have tried 'export pdf' and 'print to pdf' printer, results are even worse.
I changed to print from TechDraw and from Sketcher for no avail (it somehow permanently changed the output to 80% of the size!).
What you mean by printer automatic scaling? Is that a FreeCad or printer setting?
My DeskJet printer is calibrated as is evident by other software, so calibration must come from FreeCad.
Any other idea that may help?
Tadinltd
Postby chrisb » Mon Oct 28, 2019 8:35 am
All of these print what you see in 3D view. This has absolutely nothing to do with the dimensions of your object, it's useless for your purpose.
Printing from Sketcher is the same as above. TechDraw has a scale for pages and views. Make sure it is set to 1! I would recommend you upgrade to 0.18 or 0.19, because only these versions are currently supported.
It's a printer setting.
If you don't succeed, upload a FreeCAD file containing a TechDraw view of your object which you want to print and we can try to get things sorted.
pl7i92LCNC
Postby pl7i92LCNC » Mon Oct 28, 2019 8:45 am
as well you need in 2D to take kare of the linewidth it may give you also some persentige as part lines are usaly 0,7mm in draw
tadinltd
Postby tadinltd » Tue Oct 29, 2019 1:58 pm
Well, I upgraded to 0.18 (not thinking it will solve my specific printing problem though), and to my surprise the Print command on 0.18 does not seem to work at all. I have now 0.17 and 0.18 side-by-side.
I Don't know if this is a bug, but suggest someone with more FC experience to try and report.
In any case, I attach here a very simple drawing that I wish to print as 2D with accurate dimensions.
I use an HP DeskJet 46XX series printer with Win10 Pro.
Fork1.FCStd
(15.27 KiB) Downloaded 6 times
Thx.
Roy_043
Postby Roy_043 » Tue Oct 29, 2019 2:07 pm
With your procedure (File -> Print) the scale of the PDF depends on the current zoom level. As already mentioned: you need to use the TechDraw WB.
