[SOLVED] Why does edges in TechDraw output are sometimes not connected?
ceremcem
Post by ceremcem »
I'm preparing laser cut drawings (dxf) from 3D drawings. When I use the boolean operations to generate the end object and get the projection in TechDraw, sometimes (for some drawings) it produces some unconnected edges. The output of TechDraw "looks like" correct, but it doesn't produce a closed curve:
The model is private, so I can't share it here. However, I may try to reproduce the problem (obviously, which will take some time) or follow your directions. The problematic section is a "Boolean Cut" result of "Some geometry I draw" and "offset in 3D" of "some geometry I draw":
wandererfan
Re: Why does edges in TechDraw output are sometimes not connected?
Post by wandererfan »
ceremcem wrote: Fri Nov 01, 2019 3:40 am I'm preparing laser cut drawings (dxf) from 3D drawings. When I use the boolean operations to generate the end object and get the projection in TechDraw, sometimes (for some drawings) it produces some unconnected edges. The output of TechDraw "looks like" correct, but it doesn't produce a closed curve:
What happens if you use "Project shape" from the Drawing WB? Are the edges connected?
Beyond that, it is going to be hard to diagnose without a file.
ceremcem
Post by ceremcem »
Hi wandererfan,
I can send the project files to you privately, that wouldn't be a problem. However, it requires @realthunder's Assembly3 WB.
wandererfan
ceremcem wrote: Fri Nov 01, 2019 8:50 pm I can send the project files to you privately, that wouldn't be a problem. However, it requires @realthunder's Assembly3 WB.
Send the file please. I'll build A3WB over the weekend and get back to you.
ceremcem
Post by ceremcem »
Sorry, it's been a while that I had to dive into the work other than mechanical drawings and there were no notifications in my mailbox since then. I'm sending you the whole project via DM.
wandererfan
ceremcem wrote: Tue Feb 11, 2020 8:38 pm I'm sending you the whole project via DM.
My Asm3 install seems to be broken. I'll have to sort that out before I can look at the files.
wandererfan
Are you using a special build? If I try to load your files with the current AppImage (FreeCAD_0.19-19541-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage)
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.19541 (Git) AppImage
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/Canada (en_CA)
I get pages of messages like the following. That first line indicates that my version is looking for a property that isn't in the FCStd file or maybe has a different name.
Invalid Document.xml: End of document reached
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 197, in onDocumentRestored
    self.linkSetup(obj)
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 2744, in linkSetup
    o.Proxy.parent = self
<class 'AttributeError'>: 'NoneType' object has no attribute 'parent'
    self.linkSetup(obj)
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 3519, in linkSetup
    cstr = getProxy(o,AsmConstraint)
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 25, in getProxy
    checkType(obj,tp)
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 21, in checkType
    raise TypeError('Expect object {} to be of type "{}"'.format(
<class 'TypeError'>: Expect object tb6600_module#Constraint008 to be of type "AsmConstraint"
  File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 274, in claimChildren
    return self.ViewObject.Object.Group
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Group'
ceremcem
Post by ceremcem »
Yes, I'm using the version usually directly compiled from the latest git commit. Here is my current version:
OS: Debian GNU/Linux 9.5 (stretch)
Version: 0.19.18707 (Git)
Branch: LinkStage3
Hash: 5a598e96321da61fcb25e52beca6a33454ac5e40
Python version: 2.7.13
If you like, you can use my build scripts with a clean Debian virtual machine: https://github.com/ceremcem/build-freecad-asm3/
wandererfan
Validate Sketch says the sketch for "2mm_metal_wall" has missing coincidences and open vertices. Looks like the trouble starts somewhere before TD.
ceremcem
Post by ceremcem »
Thanks for introducing ValidateSketch tool to me. Unfolding the same part has proper DXF output if we use the "Unfold" solid, not the "Unfold_Sketch". Similarly, if I enter the edit mode of the Unfold_Sketch (wall_unfold in my project) I can see the unconnected vertices:
So yes, it's not related with TechDraw WB, it's probably related with SheetMetal WB. Thank you for finding this out.
