[SOLVED] Why does edges in TechDraw output are sometimes not connected?
I'm preparing laser cut drawings (dxf) from 3D drawings. When I use the boolean operations to generate the end object and get the projection in TechDraw, sometimes (for some drawings) it produces some unconnected edges. The output of TechDraw "looks like" correct, but it doesn't produce a closed curve:
The model is private, so I can't share it here. However, I may try to reproduce the problem (obviously, which will take some time) or follow your directions. The problematic section is a "Boolean Cut" result of "Some geometry I draw" and "offset in 3D" of "some geometry I draw":
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
- wandererfan
Re: Why does edges in TechDraw output are sometimes not connected?
What happens if you use "Project shape" from the Drawing WB? Are the edges connected?ceremcem wrote: ↑Fri Nov 01, 2019 3:40 am I'm preparing laser cut drawings (dxf) from 3D drawings. When I use the boolean operations to generate the end object and get the projection in TechDraw, sometimes (for some drawings) it produces some unconnected edges. The output of TechDraw "looks like" correct, but it doesn't produce a closed curve:
Beyond that, it is going to be hard to diagnose without a file.
Hi wandererfan,
I can send the project files to you privately, that wouldn't be a problem. However, it requires @realthunder's Assembly3 WB.
- wandererfan
Sorry, it's been a while that I had to dive into the work other than mechanical drawings and there were no notifications in my mailbox since then. I'm sending you the whole project via DM.
- wandererfan
- wandererfan
Are you using a special build? If I try to load your files with the current AppImage (FreeCAD_0.19-19541-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage)
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.19541 (Git) AppImage
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/Canada (en_CA)
I get pages of messages like the following. That first line indicates that my version is looking for a property that isn't in the FCStd file or maybe has a different name.
Invalid Document.xml: End of document reached
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 197, in onDocumentRestored
self.linkSetup(obj)
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 2744, in linkSetup
o.Proxy.parent = self
<class 'AttributeError'>: 'NoneType' object has no attribute 'parent'
self.linkSetup(obj)
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 3519, in linkSetup
cstr = getProxy(o,AsmConstraint)
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 25, in getProxy
checkType(obj,tp)
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 21, in checkType
raise TypeError('Expect object {} to be of type "{}"'.format(
<class 'TypeError'>: Expect object tb6600_module#Constraint008 to be of type "AsmConstraint"
File "/tmp/.mount_FreeCAX1codS/usr/lib/python3.8/site-packages/freecad/asm3/assembly.py", line 274, in claimChildren
return self.ViewObject.Object.Group
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Group'
Yes, I'm using the version usually directly compiled from the latest git commit. Here is my current version:
If you like, you can use my build scripts with a clean Debian virtual machine: https://github.com/ceremcem/build-freecad-asm3/
OS: Debian GNU/Linux 9.5 (stretch)
Version: 0.19.18707 (Git)
Branch: LinkStage3
Hash: 5a598e96321da61fcb25e52beca6a33454ac5e40
Python version: 2.7.13
- wandererfan
Validate Sketch says the sketch for "2mm_metal_wall" has missing coincidences and open vertices. Looks like the trouble starts somewhere before TD.ceremcem wrote: ↑Fri Nov 01, 2019 3:40 am I'm preparing laser cut drawings (dxf) from 3D drawings. When I use the boolean operations to generate the end object and get the projection in TechDraw, sometimes (for some drawings) it produces some unconnected edges. The output of TechDraw "looks like" correct, but it doesn't produce a closed curve:
Thanks for introducing ValidateSketch tool to me. Unfolding the same part has proper DXF output if we use the "Unfold" solid, not the "Unfold_Sketch". Similarly, if I enter the edit mode of the Unfold_Sketch (wall_unfold in my project) I can see the unconnected vertices:
So yes, it's not related with TechDraw WB, it's probably related with SheetMetal WB. Thank you for finding this out.
