[TechDraw] crash on showing invisible edges
uwestoehr
Postby uwestoehr » Fri Nov 01, 2019 10:52 pm
- select in the tree view a ProjectionGroup
- press in the toolbar the button "Show/hide invisible edges in a View"
result:
Reading failed from embedded file: PartShape48.bin (0 bytes, 2 bytes compressed)
Illegal storage access...
<Exception> Illegal storage access! Please save your work under a new file name and restart the application!
- press the toolbar button again
result: crash
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18652 (Git)
Hash: 223d41c676aa9ef0afb6e5061c3f0438ab9f0e0c
Python version: 3.6.8
Qt version: 5.12.1
wandererfan
Re: [TechDraw] crash on showing invisible edges
Postby wandererfan » Sat Nov 02, 2019 12:28 am
result:
I get a completely different error, but still a crash.
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.18646 +2 (Git)
Build type: debug
Branch: Extent
Hash: ce4cad08f520c54e963ea624a72ce86a529fe3bf
Qt version: 5.9.5
It should give you a selection error since show/hide only works on Views, not ProjectionGroups. Fix to master tomorrow.
uwestoehr
Postby uwestoehr » Sat Nov 02, 2019 12:52 am
Many thanks for your quick help, however, I vote that the button is only enabled when you are in a view. Otherwise it is disabled.
wandererfan
Postby wandererfan » Sun Nov 03, 2019 6:49 pm
Crash should be fixed by git commit f3c6db990c.
Selection rules and active/inactive state adjusted too.
uwestoehr
Postby uwestoehr » Sun Nov 03, 2019 7:04 pm
Thanks! The crash is fixed but not the state. Select e.g. a balloon or whatever you like and you can see that the toolbar button never gets disabled. it should be disabled by default and only be enabled if the selection makes sense.
