[solved] FreeCAD version bug?
easyw-fc
Postby easyw-fc » Tue Nov 05, 2019 11:34 am
On Linux, when I get the FC Version through python I get:
App.Version()
['0', '18.3', '', 'https://code.launchpad.net/~vcs-imports/freecad/trunk', '2019/07/19 03:19:03']
This is a bug compared to what I normally get i.e. on Win Conda build and what was normally used:
App.Version()
['0', '18', '4 (GitTag)', 'git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-18', '2019/10/22 16:53:35', 'releases/FreeCAD-0-18', '980bf9060e28555fecd9e3462f68ca74007b70f8']
here my full FC info for Linux:
OS: Linux Mint 19.1
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
and for Win:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
This is breaking some of my scripts for KiCad... I can patch mine, but I think this should be fixed anyway
Maurice
openBrain
Re: FreeCAD version bug?
Postby openBrain » Tue Nov 05, 2019 3:49 pm
You can insert a coin on this thread. ;)
Edit : As a dirty solution, would that help if the missing fields are replaced by empty ones ?
easyw-fc
Postby easyw-fc » Tue Nov 05, 2019 5:04 pm
No, the issue is that the second field is '18.3' (or '18.4') instead of '18' as it should be.
The strange is that in Win I get the right App.Version() format.
Normally the Version()[0] is Major, and Version()[1] is Minor and the last is on third field...
sgrogan
Postby sgrogan » Tue Nov 05, 2019 5:22 pm
The problem is to support the point release format we have to hack the version.h at build time. It looks like the hack that I used on win doesn't break your script and the patch used on the PPA does.
"fight the good fight"
easyw-fc
Postby easyw-fc » Tue Nov 05, 2019 5:44 pm
No problem by my side if this is a requirement to facilitate to add a release to the building ...
I can easily fix my scripts :D
Thanks for clarification...
sgrogan
Re: [solved] FreeCAD version bug?
Postby sgrogan » Tue Nov 05, 2019 9:30 pm
IMHO this is a workaround not a fix ;)
@triplus explains best here: https://forum.freecadweb.org/viewtopic. ... 30#p345112
We need to find a real solution.
