[Solved] no filled face possible
- microelly2
I try to create a filled face from a closed BSpline curve.
I tested wit a single curve, with a splitted curve into 2 or 3 segments. But filled face does not work for me.
sh=Part.makeFilledFace(Part.sortEdges([sh.Edge1,sh.Edge2,sh.Edge3])[0])
Part.OCCError: Failed to created face by filling edges
creating a planar Face works.
Any ideas?
OS: Ubuntu 14.04.6 LTS (Unity/ubuntu)
Version: 0.19.18403 (Git) AppImage
Hash: 0717b4fc23ef1db70964c3977d25e2fe46a739d1
Python version: 3.7.3
Qt version: 5.12.5
Any ideas?
Qt version: 5.12.5
Re: no filled face possible
It fails here the same way with the file you attached.
Notice this succeeds creating a face by using 2 times Draft/Upgrade on it. But I guess this isn't what you intend.
Anyway, I can very simply create a filled face from a single closed BSpline.
On the attached example file, just run :
HTH
OS: Ubuntu 18.04.3 LTS (KDE/plasma)
Version: 0.19.18645 (Git)
Build type: Unknown
Hash: 95f18a7507dec0a033e79764025f31d390832449
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
App.ActiveDocument.addObject('Part::Feature').Shape = Part.makeFilledFace(App.ActiveDocument.BSpline.Shape.Edges)
Build type: Unknown
Qt version: 5.9.5
- bspline.FCStd
- (4.55 KiB) Downloaded 13 times
This works for me :
doc1 = FreeCAD.getDocument('no_filled_face_possible')
o1 = doc1.getObject('ID_5488c410_6dbb_4d4b_a08c_dad9ce92519c')
sh = o1.Shape
w = Part.Wire(sh.Edges)
sh = Part.makeFace(w, 'Part::FaceMakerSimple')
sh.check() # ---> reports errors
sh.validate()
sh.check() # ---> seems to be fixed
Part.show(sh)
If I'm correct, these 2 lines are exactly what 2 successive Draft/Upgrade do.Chris_G wrote: ↑Tue Nov 05, 2019 4:03 pm This works for me :Code: Select all
w = Part.Wire(sh.Edges) sh = Part.makeFace(w, 'Part::FaceMakerSimple')
Hi Thomas,microelly2 wrote: ↑Tue Nov 05, 2019 2:53 pm I try to create a filled face from a closed BSpline curve.
Any ideas?
no_filled_face_possible.FCStd
Qt version: 5.12.5
please try OpenSCAD-Workbench Convert Edges to Faces .
Best regards
Wilfried
- microelly2
Thank you all for the feedback.
For my first file the edges all belong to a plane. so Part.Face works here,
But in general I have to handle nonplanar curves
the workarounds, Draft upgrade, Openscad method all do no work because they use Part.Face.
here I have the nonplanar version.
working with line segments works but working with bspline doesnt work.
But I need a filledFace version which works on any closed edge list.
… using in CurvesWB the combined_projection_curve to generate 3D BSplines with SketcherWB,
you are able to create a filled 3D-Surface - but it is not parametric when modifying sketches.
- no_filled_face_possible_2.FCStd
- (55.71 KiB) Downloaded 11 times
- microelly2
My workflow is:
create a closed curve from a selection of given curves
than create a filled face on it.
https://youtu.be/2LGHjrvnRuU
Meantime I worked with surface workbench. the result is still not nice but it works. In a next step I will smooth the generated surface
Edit:
the other workaround is to split the curve into two segments and create a ruled surface
- microelly2
Re: [Solved] no filled face possible
https://youtu.be/Q_odR-_Yhqc
the final trick was to work with all edges an helper edges as bsplines instead of a single big spline.
