Hi All,
i've just downloaded latest version and started debugging it with lldb.
I've the same behaviour. If I edit a cell directly from it, FC will crash. If I edit int formula area it will not crash.
I've tried with an empty document and it doesn't crash. But add a part and setting some references in sketches make FC crash again.
It seems to be related at some recomputing actions (even if it's so strange).
Here is the back trace generated by lldb:
* thread #1, name = 'CrBrowserMain', queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=EXC_I386_GPFLT)
* frame #0: 0x0000000102393df9 libQt5Core.5.dylib`QMetaObject::cast(QObject const*) const + 21
frame #1: 0x00000001292c6982 SpreadsheetGui.so`SpreadsheetGui::SheetTableView::closeEditor(QWidget*, QAbstractItemDelegate::EndEditHint) + 50
frame #2: 0x00000001023ace09 libQt5Core.5.dylib`QMetaObject::activate(QObject*, int, int, void**) + 1833
frame #3: 0x0000000101b4ba3e libQt5Widgets.5.dylib`QAbstractItemDelegate::closeEditor(QWidget*, QAbstractItemDelegate::EndEditHint) + 66
frame #4: 0x00000001023ace09 libQt5Core.5.dylib`QMetaObject::activate(QObject*, int, int, void**) + 1833
frame #5: 0x00000001292b8c5d SpreadsheetGui.so`SpreadsheetGui::LineEdit::event(QEvent*) + 173
frame #6: 0x00000001019ae145 libQt5Widgets.5.dylib`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 223
frame #7: 0x00000001019af3bf libQt5Widgets.5.dylib`QApplication::notify(QObject*, QEvent*) + 1361
frame #8: 0x00000001001a52e9 libFreeCADGui.dylib`Gui::GUIApplication::notify(QObject*, QEvent*) + 89
frame #9: 0x000000010239028e libQt5Core.5.dylib`QCoreApplication::notifyInternal2(QObject*, QEvent*) + 140
frame #10: 0x00000001019e77a6 libQt5Widgets.5.dylib`___lldb_unnamed_symbol1032$$libQt5Widgets.5.dylib + 136
frame #11: 0x00000001019e7107 libQt5Widgets.5.dylib`___lldb_unnamed_symbol1028$$libQt5Widgets.5.dylib + 469
frame #12: 0x00000001019ae145 libQt5Widgets.5.dylib`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 223
frame #13: 0x00000001019af08f libQt5Widgets.5.dylib`QApplication::notify(QObject*, QEvent*) + 545
frame #14: 0x00000001001a52e9 libFreeCADGui.dylib`Gui::GUIApplication::notify(QObject*, QEvent*) + 89
frame #15: 0x000000010239028e libQt5Core.5.dylib`QCoreApplication::notifyInternal2(QObject*, QEvent*) + 140
frame #16: 0x0000000101eb8df2 libQt5Gui.5.dylib`QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) + 158
frame #17: 0x0000000101eabb2d libQt5Gui.5.dylib`QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 93
frame #18: 0x0000000101ea966e libQt5Gui.5.dylib`QWindowSystemInterface::flushWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 310
frame #19: 0x000000010e20a4ce libqcocoa.dylib`___lldb_unnamed_symbol732$$libqcocoa.dylib + 1095
frame #20: 0x000000010e20a64d libqcocoa.dylib`___lldb_unnamed_symbol733$$libqcocoa.dylib + 60
frame #21: 0x00007fff3434e367 AppKit`-[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 6840
frame #22: 0x00007fff3434c667 AppKit`-[NSWindow(NSEventRouting) sendEvent:] + 478
frame #23: 0x000000010e20d479 libqcocoa.dylib`___lldb_unnamed_symbol826$$libqcocoa.dylib + 519
frame #24: 0x00007fff341ec889 AppKit`-[NSApplication(NSEvent) sendEvent:] + 2953
frame #25: 0x000000010e212752 libqcocoa.dylib`___lldb_unnamed_symbol1006$$libqcocoa.dylib + 59
frame #26: 0x00007fff341da5c0 AppKit`-[NSApplication run] + 755
frame #27: 0x000000010e20fbf1 libqcocoa.dylib`___lldb_unnamed_symbol901$$libqcocoa.dylib + 1403
frame #28: 0x000000010238de7d libQt5Core.5.dylib`QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 265
frame #29: 0x000000010239077a libQt5Core.5.dylib`QCoreApplication::exec() + 252
frame #30: 0x00000001000ec401 libFreeCADGui.dylib`Gui::Application::runApplication() + 11265
frame #31: 0x0000000100004fa6 FreeCAD`main + 5958
frame #32: 0x00007fff62b413d5 libdyld.dylib`start + 1
frame #33: 0x00007fff62b413d5 libdyld.dylib`start + 1
I got this in console:
Process 8355 launched: '/Applications/FreeCAD.app/Contents/Resources/bin/FreeCAD' (x86_64)
FreeCAD 0.19, Libs: 0.19R18714 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Sheet Metal workbench loaded
Error in InitApplications module 'FreeCAD' has no attribute 'GuiUp'
File "<string>", line 620, in <module>
File "<string>", line 162, in InitApplications
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.7/site-packages/freecad/__init__.py", line 8, in <module>
import Draft as draft
File "/Applications/FreeCAD.app/Contents/Resources/Mod/Draft/Draft.py", line 53, in <module>
if FreeCAD.GuiUp:
AttributeError: module 'FreeCAD' has no attribute 'GuiUp'
2019-11-13 22:05:06.802127+0100 FreeCAD[8355:5606481] MessageTracer: Falling back to default whitelist
2019-11-13 22:05:27.613133+0100 FreeCAD[8355:5607113] GVA info: preferred scaler idx 0
2019-11-13 22:05:29.015953+0100 QtWebEngineProcess[8383:5607190] [User Defaults] Couldn't read values in CFPrefsPlistSource<0x108a219b0> (Domain: com.apple.universalaccess, User: kCFPreferencesCurrentUser, ByHost: No, Container: (null), Contents Need Refresh: Yes): accessing preferences outside an application's container requires user-preference-read or file-read-data sandbox access
Thread size out of range
PartDesign::Pad / Pad002: Links go out of the allowed scope
Not yet supported geometry for external geometry
Clear constraints to external geometry
Version tried is:
OS: macOS Mojave (10.14)
Version: 0.19.18714 (Git)
Hash: a7ad04ba4aefb486fbc5e7c68da3dd488443b08c
Python version: 3.7.3
Qt version: 5.12.5
Locale: Italian/Italy (it_IT)
I hope this info can be useful. I can add other info. Just ask.
Luca
