[Solved] Ticket #4191 - Crash on spreadsheet in-cell value edit
lpala
Re: Crash on spreadsheet in-cell value edit
Postby lpala » Thu Nov 14, 2019 6:35 am
ulrich1a wrote:
Wed Nov 13, 2019 10:05 pm
lpala wrote:
Wed Nov 13, 2019 9:16 pm
I can add other info. Just ask.
Can you post an example file, which contain all the elements, where you would get the crash in the next step?
Ulrich
Sure,
here it is. Everything I change in-cell makes FC crash, even if I change a cell that has no alias.
Luca
RoundedBox.FCStd
File that makes FC crash
(108.08 KiB) Downloaded 7 times
lpala
Postby lpala » Thu Nov 14, 2019 7:48 am
sgrogan wrote:
Wed Nov 13, 2019 10:08 pm
I hope this info can be useful. I can add other info. Just ask.
Hey Luca
Can you uninstall Sheet Metal ad-on and try again?
Just tried... same behaviour.
Luca
Postby chrisb » Thu Nov 14, 2019 4:22 pm
You can try to delete or move the complete config folder.
veeman
Postby veeman » Thu Nov 14, 2019 5:35 pm
Hey, im experiencing the same issue under Windows.
Changing an aliased value in the spreadsheet forces FreeCAD to crash mostly.
I attached an example file too.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18686 (Git)
Hash: f0cdad7f708c0185961cd7185e366df22e041d02
Python version: 3.6.7
Qt version: 5.12.1
TerminalStrip.FCStd
(32.9 KiB) Downloaded 8 times
Postby chrisb » Thu Nov 14, 2019 8:20 pm
Please start FreeCAD from console and create a logfile using the additional parameter -l (small letter L).
ulrich1a
Postby ulrich1a » Thu Nov 14, 2019 9:48 pm
I can confirm the crashes with the two posted models under Linux.
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.19.18569 (Git)
Build type: Unknown
Branch: Rueck6
Hash: 788a509184bdd47517b04da5be18bdbc30919e8f
Python version: 3.7.3
Qt version: 5.11.3
It crashes only if I leaf the spreadsheet cell with the return key. It does not crash, when I just click into a different cell after changing the value.
I could not build myself a model that crashes. This seems to be a complicated issue.
Ulrich
FreeCAD.log.crash2.zip
(2.76 KiB) Downloaded 4 times
veeman
Postby veeman » Fri Nov 15, 2019 1:04 pm
Like ulrich1a said it only happens when return is pressed.
It also works when I change the values within a macro:
import FreeCAD
import Spreadsheet
doc = App.ActiveDocument
if doc is not None:
	Gui.activateWorkbench("SpreadsheetWorkbench")
	sheet = doc.getObject('Spreadsheet')
	if sheet is not None:
		sheet.set('LengthA', str('=100mil'))
		doc.recompute()
FreeCAD.log.crash.sheet.win10.zip
(10.62 KiB) Downloaded 5 times
lpala
Postby lpala » Fri Nov 15, 2019 1:51 pm
I can confirm. It crashes only on return. Changing the value in other ways doesnt crash.
ulrich1a
Postby ulrich1a » Fri Nov 15, 2019 4:41 pm
The crash seems to be depend on the complexity of the model. I made a block with three round holes in it. I can change the radius of the holes without a crash, until a radius is big enough, so that all three holes cross each other. The attached model crashes, if the value "Radius" in the spreadsheet is 10 or bigger.
This logs are pointing to event handling. This is something for experts in this field.
Ulrich
SpreadsheetCrash3.FCStd
(87.59 KiB) Downloaded 8 times
lpala
Postby lpala » Fri Nov 15, 2019 6:49 pm
Ulrich
Same behaviour here. It the model is VERY simple it doesn't crash. As stated before, it seem to be related to some recomputing that happens always (even if I change not aliased cell).
Luca
