Points and ray quote view in sketcher
Dear,
it is possible change the view of points and ray quote?
The points (Part.point in sketcher creation) is showed identically to the vertexes of objects.
The ray is showed as distance.
It is possible change points view as X or some different to the vertexes? now it is difficult see when points have 'coincident' constraint
Tra ray quote is possible to add "R" prefix?
Thank you
Dino
Thank you
Dino
- Raggio.PNG (10.91 KiB) Viewed 1103 times
Re: Points and ray quote view in sketcher
Both is currently not possible for simple users.
How would you see with the rays that points are coincident?
There is no bug,
what I would like is just that when I go to edit a sketch it is easier to graphically identify the points of coincidence between the various drawn entities (as it's when there is tangent) and to distinguish the radius dimensions with respect to linear dimensions
I think I understand now better what you want. The image above suggested you want to change the point always to have the rays x. If it has the rays x only in case of a coincidence that may help identifying coincident points. And the R could be added as well, although a radius dimension can be easily identified if you show it at a certain angle (as in your image). If the units are suppressed by preference setting I would like to see the R to be suppressed too.
I have seen and investigated many sketches my own as well as those from other users, and the rayedx'ed coincidence may help identifying issues, although, as time goes by and experience rises, less issues occur and less clutter is highly appreciated.
Please notice that in dino's original comment, by "ray quote" he meant "radius dimension". Things are lost in translation. The word "ray" originally provides from Latin "radius", so maybe dino, who is maybe Italian or Greek, didn't know how to translate that.
What he wants is (1) a way to distinguish object vertices from other points. And (2) to improve the way radius dimensions appear.
I had seen the proposed new coincidence symbol as a point with rays (like sunrays).
If you read the first post he called this "view as an X".
Dino, if what you propose is that the Endpoint display of Sketcher Geometry changes to show the X after a (Coincident?) Constraint has been applied to it, loosely based on your image (in which a Constraint hasn't been applied to the "better" Point displaying the X):
I think it's a good idea and worth a Feature Request in the bug tracker.
I have corrected my post above and support bejant's suggestion.
