Ticket #4197 - Error Using Expression to Fill PropertyString
wandererfan
Postby wandererfan » Mon Nov 18, 2019 12:27 pm
Is there a problem using spreadsheet cell value to fill a PropertyString? I've tried with a few different PropertyStrings and the behaviour seems consistent.
Starting with the attached file,
- Select "Cube"
- select "Rename" from RMB context menu
- press Expression icon
- assign "Spreadsheet.A1" as new Label
- press Recompute
- result :
<Exception> basic_string::_M_construct null not valid
in property binding 'Label'
101.749 <App> Document.cpp(3440): Failed to recompute ExpressionRefToSpreadsheet#Box: basic_string::_M_construct null not valid
Recompute failed! Please check report view.
<class 'SystemError'>: <built-in method recompute of App.Document object at 0x5595de0a3cb8> returned a result with an error set
120.544 <App> Document.cpp(3440): Failed to recompute ExpressionRefToSpreadsheet#Box: basic_string::_M_construct null not valid
And a popup:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
ExpressionRefToSpreadsheet.FCStd
(4.06 KiB) Downloaded 9 times
Reason: Added ticket number to thread title
Re: Error Using Expression to Fill PropertyString
Postby chrisb » Mon Nov 18, 2019 2:10 pm
FreeCAD crashes if I recompute your file.
Postby chrisb » Mon Nov 18, 2019 2:24 pm
I investigated this a bit further
- If I enter an expression Spreadsheet.A1 for the label, the contents of A1 is shown correctly
- however, the cube is still marked for recompute
- if I recompute, FreeCAD crashes
- I experience the same behaviour as in the previous 3 steps if I use an alias for Cell A1
- I can save the file before the recompute is performed
- when I reopen it, the cube has the new name and is marked for recompute.
- and if I recompute, ... (see above)
OS: macOS High Sierra (10.13)
Version: 0.19.18694 (Git)
Hash: c3ba04183e016e15410d84bae4d00556d22c7da5
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
wandererfan
Postby wandererfan » Tue Nov 19, 2019 12:21 pm
adrianinsaval
Postby adrianinsaval » Sun Dec 08, 2019 2:33 am
ezzieyguywuf wrote:
realthunder wrote:
Sorry to bother you guys, maybe one of you is willing to tackle this issue?
realthunder
Re: Ticket #4197 - Error Using Expression to Fill PropertyString
Postby realthunder » Mon Dec 09, 2019 12:41 am
PR submitted here
adrianinsaval
Postby adrianinsaval » Mon Dec 16, 2019 8:37 pm
PR submitted here
Thanks!
