Line, hatch and dimension problems
Paulpot
Postby Paulpot » Tue Nov 19, 2019 6:33 pm
1. Line: Not sure what I did, but now all my attempts to draw line is failing.
I'm not getting the usual square and circle symbol for a new line (Line 037).
2. Dimension: Don't see the dimension I created for "Line".
3. Hatch: I created outer perimeter and inner perimeter to create hatch and then delete the inner perimeter by exploding at the end (something you see in AutoCAD).
Attached is the freecad file.
Thanks a lot!
870.FCStd
(34.44 KiB) Downloaded 10 times
Willem
Re: Line, hatch and dimension problems
Postby Willem » Tue Nov 19, 2019 9:13 pm
Line037 and the dimension are not drawn with the Draft tools. How you made these I do not know.
Hatching is only possible in the Techdraw workbench
Paulpot
Postby Paulpot » Tue Nov 19, 2019 11:52 pm
Thanks Willem.
To achieve what I was trying to do, which workbench is the right one for me?
Thanks.
Paulpot
Postby Paulpot » Mon Nov 25, 2019 11:53 pm
In case anyone bumps into this thread in the future:
After wasting hundreds of hours, I concluded that it was a bug and the only workaround I found was the last reply in this thread. https://forum.freecadweb.org/viewtopic.php?f=3&t=32104
Reinstalling won't solve the problem just in case that's what is in your frustrated mind. This bug keeps coming and I keep doing the workaround for the time being unless someone can come up with an actual permanent fix or solution.
Postby Kunda1 » Fri Nov 29, 2019 4:32 pm
What version of FC are you using?
