Unable to import circular shapes from dxf-file
cronic.se
Postby cronic.se » Sat Nov 30, 2019 12:58 pm
Hi
I have a very frustrating issue.
I'm trying to import a simple .dxf-file from Adobe Illustrator but all that gets imported to freecad is the non-circular objects.
I have tried this in Freecad 0.17 och 0.18 and also tried to change many export settings in illustrator and import settings in freecad.
See attached pictures.
Can't understand why I don't get it to work.
Would be glad for some help.
Thanks.
Just the square is imported
Settings
From Illustrator
cronic.se
Re: Unable to import circular shapes from dxf-file
Postby cronic.se » Sun Dec 01, 2019 8:28 am
No one?
easyw-fc
Postby easyw-fc » Sun Dec 01, 2019 8:48 am
Try to use dxf legacy importer from preferences menu
ivxcvi
Postby ivxcvi » Sun Dec 01, 2019 9:10 am
Try importing the .dxf into LibreCAD & see if you can see anything that is different about the circular shapes. Are they on a different layer? Does that layer have attributes that are different from the visible shapes?
I've had a similar issue with furniture designs I downloaded. I haven't solved my particular issue yet, but LibreCAD did treat the shapes that weren't imported differently from the rest.
ulrich1a
Postby ulrich1a » Sun Dec 01, 2019 1:39 pm
I would not use a DXF-file for transfering the geometry from Adobe to FreeCAD. The DXF-capabilties of FreeCAD are limited due to the proprietary file format. You may try to get a PDF from Adobe Illustrator and import it in Inkscape. Then save the geometry as SVG in Inkscape and import this in FreeCAD. The chances are better, that you get a sufficient result.
Ulrich
cronic.se
Postby cronic.se » Wed Dec 04, 2019 11:22 am
Thanks Ulrich
SVG was the answer.
I exported it from Illustrator to SVG and then imported it to FreeCAD.
It worked strait away.
Thanks again.
