Revolution/Polar Pattern issues
I am using Freecad 0.19 and Part Design WB
I have a base feature that is created with the revolution tool (XZ plane)
Then, I subtract a sphere from its edge.
Then, I replicate that with a polar pattern using N replications (which is 22 right now)
My problem is that the polar pattern cant be applied. It could subtract only 5 spheres.
So, why this happens? Is it a bug? When I zoom in a lot in the sketch of the base feature, I see it is shifted 0.4 mm in Y axis. It looks like the revolutions is not totally centered. in Z-axis.
I don't know what to do to fix it. I tried to recreate everything from scratch but the same happens.
Re: Revolution/Polar Pattern issues
Upload your file. It's almost impossible to help based solely on the textual description.
I agree but I can't this time chrisb. I will try to recreate this issue on a simpler design to share here.
I am almost sure it is related to the B-splines. When I use them, the whole project behaves weird.
Sketching with B-splines is hard too. I can't constraint the curves together to move them freely.
You may upload your file to a publicly available file hoster. Please use one without the need of registration for downloaders.
how can we help you without any picture or file?
Facing same issue with patterns.(both 0.18 and 0.19 FreeCAD).
File attached for reference.
- polar pattern.JPG (70.27 KiB) Viewed 812 times
- polarpattern.FCStd
- (42.44 KiB) Downloaded 16 times
This seems to be an OCC issue: If I turn the seam of the first sketch, the pattern succeeds. Alas, the groove itself does not, so you may fiddle with this seam:
- Snip macro screenshot-369021.png (25.83 KiB) Viewed 807 times
Depending on the z-angle of Sketch I get quite different selections of repititions. 1,2,3, ... degrees deliver completely different results. 6 or 10 seems to be rather good, but that sure is not enough.
If I was searching for a random numbers generator I would be delighted.
You may be right about OCC issue.
Able to complete pattern with nano error (10 nm).Please find attached file.
Is there a way in FreeCAD / OCC coding that, if the calculation error is less than some threshold value(say :- less than 0.001 mm), it should follow topology ( merge points / surfaces ) instead of following calculation error.
- (114.75 KiB) Downloaded 14 times
- polar pattern2.JPG (48.63 KiB) Viewed 789 times
I was able to fix it somehow. I was having some issues like:
- Some days ago the subtractive revolution was not showing the red object which is subtracted. That makes the whole process hard. This feature looks good now.
- Also, the polar pattern was not making all of the copies I wanted. It was like the center of the polar pattern or the base feature was not aligned with the Z-axis.
