#4225 : BUG : FreeCAD crash when making draft in PartDesign
Doom-fr
Post by Doom-fr »
When I select a face of my design and click on draft, FreeCAD crashes.
It is systematic on this file and this kind of problem occurs often.
Step to reproduce :
1. open the file
2. go to Part Design
3. select the face (see attached picture to know which one)
4. click on draft icon => it crashes immediatly
I use FreeCAD_0.18-16146-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
OS: Ubuntu 18.04.3 LTS
Version: 0.18.16146 (Git) AppImage
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
Can you fix it ?
D.
protection_thermoformage_v0.FCStd
FreeCAD test file
(21.5 KiB) Downloaded 15 times
show the face to select
Re: BUG : FreeCAD crash when making draft in PartDesign
Moved to Help forum.
- Please retry with a most recent 0.19 version
- if the problem persists, you can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
- if the problem persists, create a log file by starting FreeCAD with the additional parameter -l (small letter L). The log file will be placed in your ~/.FreeCAD directory.
Oh, and I cannot confirm:
OS: macOS High Sierra (10.13)
Version: 0.19.18829 (Git)
Hash: 186d52ffd47696fadcd91369365e97f084051e7b
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
ppemawm
Post by ppemawm »
Doom-fr wrote: Tue Dec 10, 2019 12:09 pm When I select a face of my design and click on draft, FreeCAD crashes.
Works OK here:
Version: 0.18.16093 +17 (Git)
Branch: (HEAD detached at 0.18.1)
Python version: 2.7.14
OCC version: 7.2.0
When selecting the draft face (highlighted) the model disappears, but I would not call it a "Crash". Same behavior in V0.19.
Select neutral plane and image reappears, see highlight in image.
Select pull direction, I used outside corner.
Voila!
"It is a poor workman who blames his tools..." ;)
openBrain
Post by openBrain »
Doom-fr wrote: Tue Dec 10, 2019 12:09 pm Can you fix it ?
Welcome here Doom. This is already fixed. Just upgrade. ;)
Doom-fr
Post by Doom-fr »
Hi everybody and thanks for your answers.
Unfortunately none of these works.
(And when I say "crash", it is really a crash of the application with death of the full window)
Here is output for last version (I have also attached the log file) :
 ./FreeCAD_0.19-18846-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage -l
/tmp/.mount_FreeCA5IGMCX
FreeCAD 0.19, Libs: 0.19R18846 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
connect failed: No such file or directory
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f561b612f20]
#1  0x7f55ffc4c95f in PartDesign::Draft::execute() from /tmp/.mount_FreeCA5IGMCX/usr/lib/_PartDesign.so+0x167f
#2  0x7f561d3b623e in App::DocumentObject::recompute() from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADApp.so+0x9e
#3  0x7f55a04dac4c in Part::Feature::recompute() from /tmp/.mount_FreeCA5IGMCX/usr/lib/./Part.so+0xc
#4  0x7f561d354cfd in App::Document::_recomputeFeature(App::DocumentObject*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADApp.so+0x2fd
#5  0x7f561d3a985c in App::Document::recompute(std::vector<App::DocumentObject*, std::allocator<App::DocumentObject*> > const&, bool, bool*, int) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADApp.so+0x60c
#6  0x7f561d401cc2 in App::DocumentPy::recompute(_object*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADApp.so+0x382
#7  0x7f561d402144 in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADApp.so+0x24
#8  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(_PyMethodDef_RawFastCallKeywords+0x104) [0x7f561d78c034]
#9  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(_PyCFunction_FastCallKeywords+0x26) [0x7f561d78cba6]
#10  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(+0x6f3df) [0x7f561d6de3df]
#11  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x710a) [0x7f561d6dc10a]
#12  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0xac4) [0x7f561d897284]
#13  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(PyEval_EvalCodeEx+0x3f) [0x7f561d89736f]
#14  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(PyEval_EvalCode+0x1c) [0x7f561d766abc]
#15  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libpython3.7m.so.1.0(PyRun_StringFlags+0x94) [0x7f561d7b71b4]
#16  0x7f561e9c743a in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADBase.so+0x6a
#17  0x7f561ddf6168 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x98
#18  0x7f561ddf6352 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x102
#19  0x7f561ddf69f4 in Gui::Command::updateActive() from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x44
#20  0x7f557776ed76 in finishFeature(Gui::Command const*, App::DocumentObject*, App::DocumentObject*, bool, bool) from /tmp/.mount_FreeCA5IGMCX/usr/lib/PartDesignGui.so+0x2d6
#21  0x7f557776f8ed in finishDressupFeature(Gui::Command const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, Part::Feature*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) from /tmp/.mount_FreeCA5IGMCX/usr/lib/PartDesignGui.so+0x4fd
#22  0x7f557777aca5 in CmdPartDesignDraft::activated(int) from /tmp/.mount_FreeCA5IGMCX/usr/lib/PartDesignGui.so+0x375
#23  0x7f561ddff271 in Gui::Command::invoke(int, Gui::Command::TriggerSource) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x321
#24  0x7f561bd357b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x780
#25  0x7f561c54396e in QAction::triggered(bool) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x32
#26  0x7f561c545239 in QAction::activate(QAction::ActionEvent) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0xcb
#27  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5(+0x20e128) [0x7f561c5e2128]
#28  0x7f561c5e21e8 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x88
#29  0x7f561c678ffa in QToolButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0xa
#30  0x7f561c573c3e in QWidget::event(QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0xce
#31  0x7f561c679091 in QToolButton::event(QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x4f
#32  0x7f561c54882a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0xde
#33  0x7f561c54d095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x79d
#34  0x7f561ddc59e9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x89
#35  0x7f561bd1f186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x88
#36  0x7f561c54c53f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x283
#37  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5(+0x1af554) [0x7f561c583554]
#38  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7f561c5843a6]
#39  0x7f561c54882a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0xde
#40  0x7f561c54e3f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Widgets.so.5+0x1af9
#41  0x7f561ddc59e9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x89
#42  0x7f561bd1f186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x88
#43  0x7f561c0c540b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Gui.so.5+0x6d3
#44  0x7f561c0c5ff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Gui.so.5+0x175
#45  0x7f561c0b2dd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Gui.so.5+0x64
#46  /tmp/.mount_FreeCA5IGMCX/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7f5615a46f0e]
#47  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2e8) [0x7f5617f789d8]
#48  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/./libglib-2.0.so.0(+0x51c21) [0x7f5617f78c21]
#49  /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7f5617f78cae]
#50  0x7f561bd4e42b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x63
#51  0x7f561bd1bbc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x187
#52  0x7f561bd1fa39 in QCoreApplication::exec() from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libQt5Core.so.5+0x105
#53  0x7f561dd466c0 in Gui::Application::runApplication() from /tmp/.mount_FreeCA5IGMCX/usr/bin/../lib/libFreeCADGui.so+0x15b0
#54  /tmp/.mount_FreeCA5IGMCX/usr/bin/freecad(main+0x74d) [0x56112c96a7cd]
#55  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f561b5f5b97]
#56  /tmp/.mount_FreeCA5IGMCX/usr/bin/freecad(+0x451f) [0x56112c96b51f]
FreeCAD.log
(17.97 KiB) Downloaded 11 times
Doom-fr
Post by Doom-fr »
And with 0.17, it works !
Version: 0.17.13541 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.6
Qt version: 4.8.6
Doom-fr
Post by Doom-fr »
Are you agree that it is a new bug ?
And so, can I make an issue for that ?
openBrain
Post by openBrain »
Doom-fr wrote: Fri Dec 13, 2019 8:31 pm Hi,
It would be better that someone can reproduce. ;) But thanks for your perseverance.
I can't not reproduce here too, but I see you're using the AppImage while none of us do.
Guys, is there someone using 0.19 AppImage that could try to reproduce ?
OS: Ubuntu 18.04.3 LTS (KDE/plasma)
Version: 0.19.18817 (Git)
Build type: Unknown
Hash: 6d79dbea432e4c7b53b0b94667a9930b7d5b5104
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
openBrain
Post by openBrain »
Zolko wrote: Ping
@Zolko : seems from your posts that you're using AppImage. Could you please try to reproduce the bug described at OP ? Thx.
Zolko
Post by Zolko »
openBrain wrote: Sun Dec 15, 2019 3:24 pm @Zolko : seems from your posts that you're using AppImage. Could you please try to reproduce the bug described at OP ? Thx.
Doom-fr wrote: Tue Dec 10, 2019 12:09 pm Step to reproduce :
1. open the file
yes, it crashes with FreeCAD_0.19-18846.AppImage exactly as described
