KicadStepUp UI file error (solved)
jps3001
Postby jps3001 » Tue Dec 10, 2019 2:46 pm
Hi everyone
I am using Freecad 018 and have install KicadStepUp workbench thanks to the addon manager
but each time I am trying to use it the following message is displayed : UI file does not exist.
After that trying again to use this workbench nothing is working
Please help !
Thanks
easyw-fc
Re: KicadStepUp UI file error
Postby easyw-fc » Wed Dec 11, 2019 5:12 pm
Hi everyone
Please help !
Thanks
Would you please test removing the kicadStepUp addon and after install it? (using the addon manager)
Would you please post your full FC info?
jps3001
Postby jps3001 » Thu Dec 12, 2019 11:50 am
I have already several times removed and re-installed the workbench using
the addon tool without any success !
Postby chrisb » Thu Dec 12, 2019 11:53 am
For full FreeCAD infos follow the IMPORTANT link above to find out how we expect it.
easyw-fc
Postby easyw-fc » Thu Dec 12, 2019 12:16 pm
You should also try to remove your kicadstepup profile manually...
To help you more we need to know what @chrisb has asked/ suggested.
Moreover, which error do you see in your Report Panel?
jps3001
Postby jps3001 » Mon Dec 16, 2019 10:23 am
How can I see the report panel ?
Postby chrisb » Mon Dec 16, 2019 10:27 am
Menu->Views->Panels->Report view
jps3001
Postby jps3001 » Mon Dec 16, 2019 6:16 pm
Just after start I've got this:
Please look into the log file for further information
During initialization the error invalid syntax (dimensioning.py, line 53) occurred in C:\Users\vosec\AppData\Roaming\FreeCAD\Macro\Mod\FreeCAD_drawing_dimensioning-d73728a75b595e3a40e749ca1d939e218d14b11d\InitGui.py
During initialization the error invalid character in identifier (<string>, line 1) occurred in C:\Users\vosec\AppData\Roaming\FreeCAD\Macro\Mod\FreeCAD_FastenersWB-e9e382c48d1f22018b90522a4eead606e7a72bc6\InitGui.py
During initialization the error invalid character in identifier (<string>, line 1) occurred in C:\Users\vosec\AppData\Roaming\FreeCAD\Macro\Mod\kicadStepUpMod-a60a8487acd4029cf67b4df88ce5401e2df3f139\InitGui.py
loading Base
Loading Parameters
loading Gui
loading Features
loading Utils
loading Containers
During initialization the error invalid syntax (Observer.py, line 179) occurred in C:\Users\vosec\AppData\Roaming\FreeCAD\Macro\Mod\Part-o-magic-a53da7cce91293eec84d3b00afd92408688dfddc\InitGui.py
and after trying to open the KicadStepUp workbench:
File "<string>", line 182, in Initialize
jps3001
Postby jps3001 » Fri Dec 20, 2019 5:23 pm
Can someone help me with this issue ?
easyw-fc
Postby easyw-fc » Fri Dec 20, 2019 5:54 pm
If you want effective help, you have to:
1) you need to post your full FC info
2) attach a FC logfile to your post
