A tapered thread with more problems
Bad cut with making threads
As you can see from the image, after doing the sweep with the triangle, and applying the Boolean cut operation - the cut only removed the left half of the triangle. Any idea what is going on, and how to fix this?
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Qt version: 5.6.2
- Bad_Cut.PNG (286.37 KiB) Viewed 1265 times
Re: Bad cut with making threads
Adding the file.
- Trans_to_Fitting.FCStd
- (60.22 KiB) Downloaded 37 times
You are adding thread on tapered surface .
Your triangle profile is in tapered surface, modify it to go out of tapered surface to see the cut properly(correctly). Hope this helps.
That did the trick! Thanks,Rana.
- papyblaise
Manage 0.3mm to right for the sketch of the cylinder , or to left for the triangle , and all is perfect , especialy for the begening of the thread to the chanfer
- filting.PNG (65.51 KiB) Viewed 1243 times
If you work in PartDesign, you should use a PartSesign subtractive pipe to create the thread.
- Snip macro screenshot-26cccc.png (16.69 KiB) Viewed 1238 times
I fixed the taper problem, as you can see from trans_to_fittings2 and got exactly the threads I wanted. However, when I added a fillet to the outer radius and a small cylinder to the outer rim, everything changed & I lost my threads.
It did tell me that I was working with an inactive form. What does that mean & how do I fix that?
Where did my threads go & how do I get them back?
Qt version: 5.6.2
Qt version: 5.6.2
- Trans_to_Fitting2.FCStd
- (155.45 KiB) Downloaded 54 times
- Trans_to_Fitting3.FCStd
- (166.32 KiB) Downloaded 32 times
Re: A tapered thread with more problems
I have found it's best to add the thread instead of trying to cut it out. I also added a starter to the thread. I changed many dims so this is an example.
- Thread1.JPG (74 KiB) Viewed 1201 times
- thread1.FCStd
- (524.1 KiB) Downloaded 38 times
- papyblaise
erase Cut , do the small Pad , the chanfer , and finish by Cut , if you need add some other op , allway finish by Cut
- filting-3.PNG (20.93 KiB) Viewed 1193 times
I joined your two topics. Please create new topics for new questions or issues and reuse existing if you add contributions to them.
