Fasteners Workbench
gunasekaramani
Fasteners Workbench
Postby gunasekaramani » Fri Dec 13, 2019 6:14 am
In fasteners workbench, I select the ISO4032 nut its diameter is M6, but I need a M4 diameter with inner thread, while I selecting this parameter which I want it shows " Shape is not a shell ", how do I fix this bug. If it is possible, show me how to do that. And I attached screenshot and document with this description. And I have use the Freecad 0.18 version.
Nut.FCStd
(11.08 KiB) Downloaded 5 times
Jee-Bee
Re: Fasteners Workbench
Postby Jee-Bee » Fri Dec 13, 2019 8:47 am
Please can a mode move this thread to open discussion or so. Unrelated to partdesign
Postby chrisb » Fri Dec 13, 2019 9:34 am
Search the forum for "fasteners M4 shape is not a shell" and you will find https://forum.freecadweb.org/viewtopic.php?t=41200.
papyblaise
Postby papyblaise » Fri Dec 13, 2019 10:53 am
yes M5 or smaller don't exist in thread version , if you have absolut necessite you can import the nut , import a screw at same dia , thread=True , and soustract booleen
gunasekaramani
Postby gunasekaramani » Fri Dec 13, 2019 11:54 am
can you sent this file?
papyblaise
Postby papyblaise » Fri Dec 13, 2019 12:01 pm
yes
M5 nut.FCStd
(101.58 KiB) Downloaded 4 times
shaise
Postby shaise » Fri Dec 13, 2019 12:58 pm
In FreeCad 0.18/0.19 (uses OCC v7.3) some of the Fasteners exhibit this issue. If you try FreeCad V0.17 it will work. (This is what I do when I need to 3D print threads)
Syres
Postby Syres » Fri Dec 13, 2019 1:13 pm
0.17 didn't work for me but 0.16 produces a M4 4032 Nut with threads, I always make a Part>Simple Copy if in doubt before bringing the file into a newer FreeCAD version:
OS: Windows 7
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Postby chrisb » Sat Dec 14, 2019 12:16 am
I have manually created an M4 nut in 0.19 using the profile with the cut off triangle from my machinery handbook:
Snip macro screenshot-8aa830.png (9.64 KiB) Viewed 167 times
So current OCC is able to produce such threads. So Fasteners may be able to create them too.
I have also tried to set the 3D printing factors to A=1 and B=0, but it did not help creating an M4 threaded nut.
If I can do anything else to help, please let me know.
m4.FCStd
(110.12 KiB) Downloaded 5 times
