Hi,everyone.
I always get a mesh obj, when I insert a model in obj format.But I want to turn this object to a topoShape, which can be used in Part workbench.How can I do it?
How to turn mesh shape to topoShape?
Re: How to turn mesh shape to topoShape?
Moved to help forum.
There are lots of forum topics explaining how to convert a stl to a solid. Basically, you import the file as a mesh, convert in Part workbench the mesh to a shape and the shape to a solid.
Use Part_ShapeFromMesh.
In the process of converting mesh to Part, I encountered new troubles. Some obj model files are very slow in the process of converting to Part. I traced the code and found that the code that affects speed is in the function of setFace. One of them is aSewingTool.Perform ().
As far as I know, the function of this function is to stitch triangle patches.
void TopoShape::setFaces(const std::vector<Base::Vector3d> &Points,
const std::vector<Facet> &Topo, float Accuracy)
gp_XYZ p1, p2, p3;
TopoDS_Vertex Vertex1, Vertex2, Vertex3;
TopoDS_Face newFace;
TopoDS_Wire newWire;
BRepBuilderAPI_Sewing aSewingTool;
Standard_Real x1, y1, z1;
Standard_Real x2, y2, z2;
Standard_Real x3, y3, z3;
aSewingTool.Init(Accuracy,Standard_True);
TopoDS_Compound aComp;
BRep_Builder BuildTool;
BuildTool.MakeCompound(aComp);
unsigned int ctPoints = Points.size();
for (std::vector<Facet>::const_iterator it = Topo.begin(); it != Topo.end(); ++it) {
if (it->I1 >= ctPoints || it->I2 >= ctPoints || it->I3 >= ctPoints)
continue;
x1 = Points[it->I1].x; y1 = Points[it->I1].y; z1 = Points[it->I1].z;
x2 = Points[it->I2].x; y2 = Points[it->I2].y; z2 = Points[it->I2].z;
x3 = Points[it->I3].x; y3 = Points[it->I3].y; z3 = Points[it->I3].z;
p1.SetCoord(x1,y1,z1);
p2.SetCoord(x2,y2,z2);
p3.SetCoord(x3,y3,z3);
if ((!(p1.IsEqual(p2,0.0))) && (!(p1.IsEqual(p3,0.0)))) {
Vertex1 = BRepBuilderAPI_MakeVertex(p1);
Vertex2 = BRepBuilderAPI_MakeVertex(p2);
Vertex3 = BRepBuilderAPI_MakeVertex(p3);
newWire = BRepBuilderAPI_MakePolygon(Vertex1, Vertex2, Vertex3, Standard_True);
if (!newWire.IsNull()) {
newFace = BRepBuilderAPI_MakeFace(newWire);
if (!newFace.IsNull())
BuildTool.Add(aComp, newFace);
aSewingTool.Load(aComp);
aSewingTool.Perform();
_Shape = aSewingTool.SewedShape();
if (_Shape.IsNull())
_Shape = aComp;
- ttt.obj
- (561.27 KiB) Downloaded 10 times
