SVG->Shape error: Part.BSplineCurve object has no attribute 'Axis'
falviani
Postby falviani » Thu Dec 19, 2019 5:50 pm
My setup:
OS: Windows 10 (10.0)
Version: 0.19.18644 (Git)
Hash: 481870be2b48ef95b59acf1440b069d42b6fad23
Python version: 3.6.7
Qt version: 5.12.1
I created a document, then in the draft WB imported an SVG as geometry; the image was created and simplified in InKscape. After selecting all parts I converted the path objects to sketches and merged them. With the merged sketch selected I created a job, set up the tool, etc. I learned this approach (use an engrave op with the sketch as the only object in the file - thanks ChrisB!) when trying to create a grid for a wasteboard.
Trying to create an engrave operation just complains with the error: Unnamed#Engrave: 'Part.BSplineCurve' object has no attribute 'Axis'
Editing the sketch shows that it is composed entirely of bsplines. Is there a reasonable way to convert them to curves so I can continue (or some other fix)?
Thanks in advance,
Frank
SCG Text Test.FCStd
(55.47 KiB) Downloaded 3 times
Re: SVG->Shape error: Part.BSplineCurve object has no attribute 'Axis'
Postby chrisb » Thu Dec 19, 2019 9:22 pm
If you have the font available you should use engrave directly on the ShapeString; it was made for that. Otherwise you can use this script. Change the precision in Line 47 from 0.2 to a value matching your needs.
wire2SketchNew.py
(1.71 KiB) Downloaded 3 times
