FC 0.19 ... What means "Could not create Collator: 4"?
lutz_dd
Postby lutz_dd » Sun Dec 22, 2019 11:43 am
FC 0.19 ... What means "Could not create Collator: 4" ?
FC 0.18 ... does not show this message.
It is issued to the ReportView in case of Edit/Preferences ...
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18760 (Git)
Hash: ef73ab5f3a330d3c44138f23290f8c9f7a334caf
Python version: 3.7.3
Qt version: 5.12.1
vocx
Re: FC 0.19 ... What means "Could not create Collator: 4"?
Postby vocx » Mon Dec 23, 2019 1:22 am
Please describe what you are doing when seeing this message. Opening FreeCAD, closing it, opening a document, using a tool, what?
I've never seen the message in the report view in 0.19. Maybe it's due to one of the external workbenches that you have installed.
easyw-fc
Postby easyw-fc » Mon Dec 23, 2019 6:56 am
This may depend on which WB you are preferences setting for...
Could you please generate a log file?
lutz_dd
Postby lutz_dd » Mon Dec 23, 2019 10:55 am
Procedure ... now using FreeCAD_0.19.18946 (with no difference)
(1) rename C:\Users\<user>\AppData\Roaming\FreeCAD to FreeCAD.merken
(2.1) Start FreeCAD
(2.2) Edit/Preferences -> General -> Output window .... enable protocol messages
ReportView prints "Failed to load UI file from ":/ui/preferences-dxf.ui"
(2.3) Close FreeCAD
(3.0) Start FreeCAD
(3.1) Edit/Preferences
At the end ReportView prints
- "Failed to load UI file from ":/ui/preferences-dxf.ui"
- "Could not create collator: 4" multiple times
Regarding workbench ... Part-WB and Start-WB are showing this information.
(a) Procedure above using Start-WB
(b) My regular startup turns on the Part-WB
easyw-fc
Postby easyw-fc » Mon Dec 23, 2019 2:02 pm
I had this issue temporarily on an older release... would you please try with latest:
FreeCAD_0.19.18990_x64_Conda_Py3QT5-WinVS2015.7z
or
FreeCAD_0.19.19036_x64_LP_12.1.2_PY3QT5-WinVS2015.7z
lutz_dd
Postby lutz_dd » Mon Dec 23, 2019 4:03 pm
With FreeCAD_0.19.18990 (FreeCAD_0.19.18990_x64_Conda_Py3QT5-WinVS2015.7z)
- ":/ui/preferences-dxf.ui" ... gone
- "Could not create collator: 4" ... no change, FC keeps reporting
