Hi Folks,
it appears to me there is an issue with constraining a line to a parabol in certain cases:
If I try to "fix a Point onto an object" the Points of lines do not match the parabols.
The same happens if I draw the Points of a line directly onto the parabols.
In both cases the constrains are listed in the GUI of the Combo view.
I tried to recreate the error with a new file but couldn't manage.
The attached Freecad file is the original one. In this file any line whose points i try to attache are misaligned.
The Report view gives the following message but I'm not sure if it belongs to my Problem:
"Attacher: linked object ImagePlane001 is unexpected, assuming it has no shape."
The python console gives no error, when i draw the line with the constraints:
App.ActiveDocument.Sketch005.addConstraint(Sketcher.Constraint('PointOnObject',57,2,34))
Maybe I did something wrong? I didn't find any info in the forum regarding issues with these type of constraint.
Unfortunately I'm not a CAD expert.
BR,
Will
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Possible Bug In Sketcher WB
- sketcher_issue.FCStd
- (10.47 KiB) Downloaded 35 times
- Unbenannt2.JPG (18.61 KiB) Viewed 530 times
- Unbenannt.JPG (14.72 KiB) Viewed 530 times
Re: Possible Bug In Sketcher WB
What you see is only a display issue. Internally the points are placed with much higher precision on the parabolic curve.
Thanks for the quick Response.
Apreciate it.
Apreciate it.
