FC 0.19 ... How can I prevent the automatic save to (change of) user.cfg?
lutz_dd
Post by lutz_dd »
How can I prevent the automatic save to (change of) the file user.cfg?
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18760 (Git)
Hash: ef73ab5f3a330d3c44138f23290f8c9f7a334caf
Python version: 3.7.3
Qt version: 5.12.1
openBrain
Re: FC 0.19 ... How can I prevent the automatic save to (change of) user.cfg?
Post by openBrain »
Run FC inside a script that saves user.cfg before launching and restores it at closing ?
Post by Kunda1 »
This is an interesting topic. An aside, several months back I was wondering about this in a different way which was: when does FC save changes to user.cfg ? I used Meld diff tool to monitor this. I backed up the user.cfg and then opened both original and backup in Meld, then I started FreeCAD. The non-technical answer (i didn't search the code to see where but through pure observation and trial and error) is when the user either opens the Preferences - changes something and accepts the changes AND/OR when the program quits. The latter will save any changes made during the usage of FreeCAD that were either novel (like downloading a new workbench) to trivial. Right before the program exits these changes are written to the user.cfg
openBrain
Post by openBrain »
Kunda1 wrote: Thu Jan 02, 2020 2:09 pm The non-technical answer (i didn't search the code to see where but through pure observation and trial and error) is when the user either opens the Preferences - changes something and accepts the changes AND/OR when the program quits. The latter will save any changes made during the usage of FreeCAD that were either novel (like downloading a new workbench) to trivial. Right before the program exits these changes are written to the user.cfg
I'd bet that the 'Save to disk' button of Parameter editor also triggers a write to user.cfg. ;)
Post by Kunda1 »
openBrain wrote: Thu Jan 02, 2020 2:16 pm
True
lutz_dd
Post by lutz_dd »
Just FYI why I'm asking ....
Jumping across 0.17/0.18/0.19/0.19latest
+ openFoam, Assembly2, As2p, Plot-WB installed
+ running multiple FC's at the same time
hase silently (step-by-step) over time deleted the content of my Part-WB Custom-Toolbar using icons of the mentioned installed WB's. The issues seems to be related to the issues of the Workbenches (eg. Py2 vs Py3). It seems run/keep older FC version +outdated AddOns a difficult task.
For this reason my user.cfg is now Git-controlled, but it is difficult to separate the wanted changes from the unwanted stuff.
Thx. folks ... will go with a wrapper script as described by openBrain.
openBrain
Post by openBrain »
Maybe just setting user.cfg as read-only can be safely handled by FC without crashing, but I'm not sure of that. ;)
