PartDesign placement issues
I think there are 2 placement issues:
1.
- in PartDesign, create a box
- select the box in the tree and use the menu Edit -> Placement
result: no matter what you do there, the box is not transformed.
2.
- right-click on a body in PartDesign
result: the context menu misses an entry to change the placement
Can I open a bug report and try to fix this or do i miss something?
1.
2.
Re: PartDesign placement issues
That's how PartDesign works: The features and sketches are not moved by their placement, but by AttachmentOffset. This is no bug.
That seems to be consistent with Part objects, where neither Box, nor cylinder, nor cone have Placement in their context menu. This is no bug.
- papyblaise
Nay the bug is in your mouse
you have to change the placement of the body , not of the box
The bug is that the menu is not disabled. Since a box cannot be placed, the menu must be disabled.
Sorry, my mistake. Of course this is no bug, but a missing feature I would like to add since it saves time.
If the placement is expanded in the Data tab, the edit fields are visible but disabled. This seems very sensible to me as a source of information. The Placement dialog serves the same purpose, alas, the input fields are not disabled. We are probably both wrong stating it is no bug: The Menu->Edit->Placement entry was probably forgotten to be disabled. An indicator for this is, that the three-dots-button does not occur in the Data tab.
If you want to allow editing placement directly, it is a strong indicator that you got the attachment of the sketch wrong. You then should reattach it directly to the body's origin and and change the AttachmentOffset there. Doing it different seems to obscure things rather than clarify. I would like to see some real life use cases showing the opposite. As allowing the direct change of Placement defeats the well established workflow of PartDesign, it might be better to create an addon, some kind of special PartDesign-Sketch-Manipulator, so that you can decide yourself if you want it or not.
If you allow changing Placement directly you should tell how and where to propagate it. Should the result of changing Placement be a change of the item to which it is attached, too?
Yes, this is what I mean. If an object is selected in the tree that cannot be transformed using the placement dialog, its menu entry must be disabled.
All I want is to add the context menu entry "Placement" for tree objects that can be transformed using the placement dialog.
The context menu of Part Objects and PartDesign Body is already rather crowded. I would prefer not fill it further. With some luck we may get a combined Placement/Transform tool, then we have it automatically in the context menu.
Btw: this PR causes a regression because now the Rotation elements are squashed in height that looks quite ugly and you can't see the numbers any more. I wonder what's the point in reducing the height of this dialog? Or does it really eat all your vertical space?
OS: Debian GNU/Linux 10 (buster) (X-Cinnamon/lightdm-xsession)
Version: 0.19.19209 (Git)
Hash: 2e31417aa46d34e01f8f815f306baead62368e38
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.4.0
Locale: C/Default (C)
br
user
