Problems with feature selection in TechDraw [0.19]
Hello all, I just switched over to the Freecad-daily PPA in LinuxMint 19.3 [Ubuntu 18.04]. The optimizations in the techdraw workbench have things running much faster. I have run into a problem however.
But first:
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
I seem to have having an issue figuring out how to select certain points and lines on the techdraw views after adding dimensions in the same area. For example: Do you see the 0.900" dimension below the 1.367" in the lower left of the page (upper left of 'Front' view)? I can't select the 0.900" dimension any more to drag it around. I can select it in the combo view, but not on the page.
Similarly, I can't select any points or lines on the left side of the same view. Anything I try and click or mouse-over just selects the 4.250" dimension instead. If I hide the dimension (or even all dimensions) parts of the drawing still remain un-selectable. Also the hole in the same view is now unselectable for a diameter callout. I can still click on the lower point, and the center-mark.
Basically it seems like after adding a dimension, large areas around it become un-selectable, even if the dimension is hidden. I tried 'toggle selectability' on a number of objects and couldn't determine that anything happened. I tried this on two different computers, same issue.
FCStd file and an svg of the drawing is attached.
Is this a bug or am I missing something obvious about how to use the TechDraw bench?
But first:
Version: 0.19.
Qt version: 5.9.5
- body_drawing.svg
- (201.31 KiB) Downloaded 28 times
- Body2.1.FCStd
- (307.78 KiB) Downloaded 40 times
Re: Problems with feature selection in TechDraw [0.19]
Hello!
Can confirm that. i have not used TechDraw for a while, but that behavior is not normal. i can not select a point. I also can not select a cross. It seems that the bounding box, or the radius for the selection, or both are increased.
Sorry for my english.
br
user
OS: Debian GNU/Linux 10 (buster) (X-Cinnamon/lightdm-xsession)
Version: 0.19.19181 (Git)
Hash: 2504247d65271b937dd5f033a0efff9c0d7bf375
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.4.0
Locale: C/Default (C)
br
user
- 01.webm
- (240.1 KiB) Downloaded 22 times
- wandererfan
Definitely a bug.
Looks like I broke it when fixing a problem with dimensions not being "unselected" when another object is selected (git commit 7e3197abe0 - about a week ago.
Phew, ok, not just me going crazy then. I'll wait for a fix. Thanks wandererfan.
- wandererfan
Should be fixed after git commit b7190a8b50
Hello!
br
user
Works! Thanks for the fast fix!
br
user
- wandererfan
That is no comparison. Your work are much more complex and consumes more time. I tested this in 5min.
Greetings
user
Would this have made it to the Daily build PPA from yesterday? I just upgraded this morning and the problem persists. Do I need to redraw the views in techdraw before the changes show up?
- wandererfan
I'm not sure when the daily builds happen. Might have to wait one more day.
You should not have to do anything to your file.
