Error when rotating an object - help please
falviani
Postby falviani » Fri Jan 10, 2020 8:12 pm
Hello All,
My setup:
OS: Windows 10 (10.0)
Version: 0.19.19151 (Git)
Hash: 1276920feaec772d297ebd9e50ee1ae2881f62fe
Python version: 3.6.8
Qt version: 5.12.1
I am trying to set up a model of an organizer stand and duplicate it so I can cut it out on my CNC router. I want the duplicate to be rotated 180 around the Z axis and re-positioned so it's close to the original, in order to use the minimum amount of material. Unfortunately, when I rotate the object I get the following error:
<Exception> Invalid type 'long'
in property binding 'AttachmentOffset'
148.352 <App> Document.cpp(3440): Failed to recompute NestedLayoutTest#Sketch001: Invalid type 'long'
Recompute failed! Please check report view.
This happens both when I copy/paste and when I use the dupicate menu item. I can translate the duplicate to a different position but rotation fails. The file is attached. Can anybody tell me what I'm doing wrong, or if this is an error?
Thanks in advance,
Frank
NestedLayoutTest.FCStd
(18.35 KiB) Downloaded 4 times
Re: Error when rotating an object - help please
Postby chrisb » Fri Jan 10, 2020 10:10 pm
I don't know what you copied, but something went out of whack. You could have copied the whole body, but not just the pad inside.
A far better solution would have been to create a Draft->Clone, because it is still dependent on the source object; i.e. if you change dimensions in the source they will change in the clone too.
