Curious behaviour after copying sketch to new body
falviani
Postby falviani » Sat Jan 11, 2020 3:30 pm
Hi all,
My setup:
OS: Windows 10 (10.0)
Version: 0.19.19151 (Git)
Hash: 1276920feaec772d297ebd9e50ee1ae2881f62fe
Python version: 3.6.8
Qt version: 5.12.1
While trying to figure out how to include multiple copies of a shape in a single file arranged so they can be cut out by a CNC router, I decided to try copying the sketch to a new body and then rotate/position it. My plan was to pad each separately then create a job with both bodies to create the toolpath.
When I did that (copy sketch, create new body, select new body, paste copied sketch), I get the following dialog:
The new body is clearly shown as active. If I select independent copies I can continue. But if I pad the 2nd sketch and try to pad the 1st sketch, I get the following error ("result has multiple solids"):
So I ask:
1) What is going on? How do I avoid this, if at all?
2) How can I use multiple copies of an object outline laid out in a single project arranged to be cut out by a CNC router? I have now spent around 2 days trying to do this with no success :(
Thanks in advance,
Frank
NestedLayoutTest.FCStd
(13.79 KiB) Downloaded 2 times
vocx
Re: Curious behaviour after copying sketch to new body
Postby vocx » Sat Jan 11, 2020 3:59 pm
A PartDesign Body is supposed to be a single contiguous solid. Read the information in that link to understand what this means. You cannot have disconnected solids in the same Body, for this you need separate Bodies.
drmacro
Postby drmacro » Sat Jan 11, 2020 4:06 pm
I'd think a set of clones is what you'd want...
Nested_clones.FCStd
(22.02 KiB) Downloaded 1 time
Postby chrisb » Sat Jan 11, 2020 4:51 pm
The images you posted are faar too small and show far too much. Post a detail enlargement of only the relevant part. I guess the popup asks you about copying. This is because the sketch is in the other body. And if you create a pad there, both solids would be independent. After copying you have to move the sketch to the right body.
