I'd like to test fit drawings before I 3D print them. My prints are bigger than real size. Can this be overcome?
I tried saving an SVG, but FreeCAD says it can't export that type.
A PDF is equally large.
OS: macOS 10.14
Version: 0.18.15525 (Git)
Hash: 1a7d3d9a37fe43468c8ac84590c1db53e2b2000a
Python version: 3.6.7
Qt version: 5.6.2
Printing in actual size
Re: Printing in actual size
How did you get your print? If you use TechDraw it is as accurate as your printer is. Make sure the printer driver does not autoscale.
I just tried to PRINT from the PartDesign tool.
I tried to follow the TechDraw tutorial, and right away I get "Template not set for page."
In Preferences, nothing is populated for a default template or template directory.
The templates directory for macos is
where the three dots at the beginning denote where you have FreeCAD installed, e.g. /Applications.
.../FreeCAD.app/Contents/Resources/share/Mod/TechDraw/Templates/
I always export my stuff as .stl's and I've never had any problems:
1. Select the body or the feature in the combo/tree view.
2. File --> Export (Or press Ctrl + E)
3. Save as type --> STL Mesh
4. Open in your favorite slicer and print.
This has always resulted in 100% accurate STLs for me.
Hope this helps!
Hope this helps!
Hey folks,
I posted a possible solution to this here:
https://forum.freecadweb.org/viewtopic. ... 20#p458468
Clif
Clif
