Ticket 0004255: Multiple issues with "utility to sweep"
axkibe
Postby axkibe » Tue Jan 21, 2020 10:11 am
I'm trying to make "rope" with "utility to sweep", first is (almost) the case I actually want (removed already everything non relevant), second is a simplified test where I just made quickly one random path.
test.FCStd
(6.77 KiB) Downloaded 8 times
test2.FCStd
(5.96 KiB) Downloaded 12 times
I already upgraded and compiled to git master (as I get version packaged debian buster is oldish)
OS: Debian GNU/Linux 10 (buster) (GNOME/gnome-xorg)
Version: 0.19.19327 (Git)
Build type: Unknown
Hash: 65c4e1bd11e0820cd1f1d6577d23bf9cdbb54247
Python version: 3.7.3
Qt version: 5.11.3
In the part workbench, I select "utility to sweep", right arrow for "selected profile" to be "circle", check "create solid", click "sweep path", go to model, try to click "wire", -> status message: "not allowed". or sometimes "selection not allowed by filter" (seems to be random which error message)
When I double click "wire", I get
  File "/home/axel/freecad-build/Mod/Draft/Draft.py", line 3244, in setEdit
    FreeCADGui.runCommand("Draft_Edit")
<class 'Base.FreeCADError'>: No such command 'Draft_Edit'
When instead of trying to select the whole path from the model view I ctrl+select all parts of the T (test2) I actually get a result, but not what I expected.
I expected a the T made of "pipes".
When using 0.18 (debian default), I can sometimes select, the model view, but same result in case of test2, never a result in case of test, here I get a message box "Input error", "NCollection_Array1::Create". (double clicking the wire in double view crashes 0.18)
I'm a little out of wits how to approach this now.
PS: A usability suggestion, when holding ctrl to select multiple things in the 3d view, accidentally clicking the background deselecting everything and having to start over again... can be aggravating.
papyblaise
Re: Multiple issues with "utility to sweep"
Postby papyblaise » Tue Jan 21, 2020 10:30 am
Hi
Fc start a sweep from the section of the profil and follow the path in a parallel plane segment by segment
If you draw the circle on the exact end of the path , it do well
T pipe.PNG (31.59 KiB) Viewed 350 times
openBrain
Postby openBrain » Tue Jan 21, 2020 10:40 am
You can use MapMode of Circle to position it on the first vertex of the path. ;)
Postby chrisb » Tue Jan 21, 2020 10:54 am
test2: Your circle lies somewhere far off the T-wire:
Snip macro screenshot-fd7645.png (3.2 KiB) Viewed 342 times
Place it properly at the end instead.
Besides, I tried to convert the wire to a sketch in order to validate, alas, it yielded an empty sketch. Does someone know the reason for this?
axkibe
Postby axkibe » Tue Jan 21, 2020 11:02 am
test2: Your circle lies somewhere far off the T-wire:Snip macro screenshot-fd7645.png
Oh thanks a lot, that explains this, so when manually selecting all sections of the T it works fine. Still confused why I cannot select the whole wire in Model view. (my actual case is more complicated, selecting all sections of the wire manually will be almost impossible)
Postby chrisb » Tue Jan 21, 2020 11:07 am
Can you check in 0.18? It may be a regression.
axkibe
Postby axkibe » Tue Jan 21, 2020 11:11 am
It works in 0.18
Syres
Postby Syres » Tue Jan 21, 2020 12:04 pm
I'm afraid it's a copy and paste from another recent post but, the Wire selection issue looks like a regression to me, last build I have that it worked as expected:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17651 (Git)
Hash: 16c26cb3b1cd7209ea8efc8cb30b3b18fd80cf95
Python version: 3.6.8
Qt version: 5.12.1
next newest build that it behaves as today is:
Version: 0.19.17803 (Git)
Hash: 89961a33d46063a43e9fb5b0308ca95d559eca94
Qt version: 5.12.1
openBrain
Postby openBrain » Tue Jan 21, 2020 12:16 pm
You need to downgrade it once to get a Part.Feature from the FeaturePython. ;) Then you can convert to sketch.
Regression confirmed here.
axkibe
Postby axkibe » Tue Jan 21, 2020 1:08 pm
Thanks everyone, finally made it!
Yes, that circle really needs to be exactly on start/finish and perpendicular (which was also not the case in my actual project) and also the points weren't in a plane as I thought (I thought naively in draft mode and having the working plane on I'd force all created points into that plane, I used the points table editor from curbs to force them all into the plane)
I had to do quite a bunch of switching between 0.18 and HEAD(0.19) as also next to sweeping the "curbs workbench" only worked with 0.18 but for example that perpendicularity macro only with HEAD(0.19).
